GSR injectors
Old Nov 11, 2007 | 01:40 PM
x4thGenCafe's Avatar
OF THE KINGS
Default GSR injectors
Will my GSR injectors work in my B16 A ?
Old Nov 11, 2007 | 02:25 PM
sirtef9's Avatar
Default Re: GSR injectors (x4thGenCafe)
what year?
Old Nov 11, 2007 | 03:16 PM
OF THE KINGS
Default Re: GSR injectors (sirtef9)
im not sure what year the injectors are from but my b16a is obd0
Old Nov 11, 2007 | 03:36 PM
sirtef9's Avatar
theyd fit make sure there obd0 though, are the b16 injectors bad?
Old Nov 11, 2007 | 03:48 PM
OF THE KINGS
idk if you scroll down the forum more on crx/ef youll see my other post.
its titled PLugs.
any help ?
Old Nov 11, 2007 | 03:51 PM
HondaCivicSiR1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x4thGenCafe &raquo;</TD></TR><TR><TD CLASS="quote">Will my GSR injectors work in my B16 A ?</TD></TR></TABLE>well since the first gsr motor that came out in 92 is obd1.i would say no because all obd0 ecu require a resister box because the injectors are peak and hold and most obd1 injectors are saturated witch means you do not need a resistor box.
Old Nov 11, 2007 | 03:53 PM
OF THE KINGS
gotchya. thanks guys
Old Nov 11, 2007 | 03:56 PM
CRX Toad's Avatar
Default Re: (x4thGenCafe)
They will fit in any B-series however if they are OBD1 they won't work OBD0 without a little work. I am locking this because it has been covered many times. thanks
jthrasher1
11
Dec 4, 2010 09:48 AM
Stiff_Crx
Jun 18, 2010 04:43 AM
EX-T
Apr 18, 2007 11:10 AM
finallyturboed301
10
Dec 8, 2006 06:35 AM
Blazin Si
Sep 21, 2004 07:10 AM
