DOHC ZC help
Old Nov 11, 2007 | 01:17 PM
andyxsauce's Avatar
Default DOHC ZC help
hi everyone i need some help with a dohc zc i just put on my ef. it was working fine for the first 2 weeks then out of no were i started to get lag on it a bit. like 2 days after the lag started it just died on me it wouldnt even idle anymore, it would just turn off. i checked my plugs and found out that they were all carbon fouled. i tried cleaning them up and and putting them back on but it just fouled them up again. i am using a pr4 on a stock dohc zc. oh and the ecu isnt giving out any engine codes or anything. does anyone know what it may be?
Old Nov 11, 2007 | 02:12 PM
superex87's Avatar
Default Re: DOHC ZC help (andyxsauce)
this seems to be a comon problem, sounds like the ignitor in the disrtibutor has gone bad
Old Nov 11, 2007 | 10:56 PM
andyxsauce's Avatar
Default Re: DOHC ZC help (superex87)
thx im gonna try that as soon as i get a chance tomorrow.
Old Nov 12, 2007 | 10:42 AM
andyxsauce's Avatar
hey i just replaced the igniter and that didnt seem to be the problem. its doing the exact same. turns on and stuff but wont idle right i have to give it gas to keep it on.
Old Nov 16, 2007 | 06:24 PM
andyxsauce's Avatar
i just started to get a code 9 that means cyp right? could this be whats wrong? i really need someones help.
Old Nov 16, 2007 | 07:54 PM
4doorsleepr's Avatar
it could be a combination of things: you could be running really rich/your not getting a good enough spark.
check the heat range on the plugs, check the wires, and check the dizzy.
but honestly man, good luck trying to find comparable parts for that ZC. i had one a while ago, and i couldn't find a whole lot
Old Nov 16, 2007 | 11:02 PM
GroundZer0 336's Avatar
Default Re: DOHC ZC help (4doorsleepr)
get a pg7 ecu... i have one i can sell you for 35 shipped... the pr4 is SO rich... i put one on my car for the hell of it and itd barely run.... trust me get a pg7 and youll be like WOW ... your just fouling out plugs and ****
Old Nov 17, 2007 | 08:54 AM
andyxsauce's Avatar
ok thx ill try that as soon as i get time.
Old Nov 17, 2007 | 09:07 AM
wiZCo's Avatar
Stouts 'n' Scotch
You need to clear up that code 9 before your car will run well. Check your wiring going to the CYP sensor at the front of the head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4doorsleepr &raquo;</TD></TR><TR><TD CLASS="quote">
but honestly man, good luck trying to find comparable parts for that ZC. i had one a while ago, and i couldn't find a whole lot</TD></TR></TABLE>
You didn't search hard enough. There are plenty of parts available for that motor. Please don't spread biased information around.l
And I would also recommend using a PM6,PG7, or PM7 ECU over a PR4, but an ECU is not the cause of your problems here.
Old Nov 18, 2007 | 05:31 PM
andyxsauce's Avatar
Default Re: DOHC ZC help (GroundZer0 336)
i tried a dif distributor that i had lying around but it did the same thing for a moment and then it just died and now my car dosnt even start anymore.
Old Nov 18, 2007 | 05:32 PM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyxsauce &raquo;</TD></TR><TR><TD CLASS="quote">i tried a dif distributor that i had lying around but it did the same thing for a moment and then it just died and now my car dosnt even start anymore.</TD></TR></TABLE>
The sensor isn't in the distributor. It's on the front side of the cylinder head and has two wires running to it.
Old Nov 18, 2007 | 06:05 PM
janz3n's Avatar
Default Re: DOHC ZC help (wiZCo)
and i hope you used a dohc zc distributor and not a d16a6 cuz it wont run.
Old Nov 18, 2007 | 06:20 PM
424racer's Avatar
check your m.a.p sensor.
or your dizzy cap and roter.
Old Nov 20, 2007 | 06:50 AM
andyxsauce's Avatar
i checked the wiring going to the cyp sensor and everything seems to look fine so im gonna replace it as soon as i get a chance.
sleepingciv
Sep 22, 2012 12:58 PM
bottledcrx
Sep 23, 2002 08:36 PM
bottledcrx
Sep 23, 2002 02:02 PM
CWBETB
Aug 26, 2002 06:50 AM
