help... del sol seats in a DA
Old Nov 11, 2007 | 09:30 AM
JDM-Punk's Avatar
Default help... del sol seats in a DA
ok i have some del sol seats that im trying to put in my da, but the sliders wont bolt right up, so i was seeing if you guys had any answers for me... oh and not sure if its just mine or every da but for the rear mounting part i have 2 mounting points for each (one one top and one angle)
yes i have searched, and found nothing
Old Nov 11, 2007 | 09:50 AM
H22AJSPEC's Avatar
Default Re: help... del sol seats in a DA (JDM-Punk)
Im sure there is probley a better way but I mounted in the holes that fit then drilled and bolted the others and used huge washers. worked fine .
Old Nov 11, 2007 | 10:19 AM
JDM-Punk's Avatar
Default Re: help... del sol seats in a DA (H22AJSPEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22AJSPEC &raquo;</TD></TR><TR><TD CLASS="quote">Im sure there is probley a better way but I mounted in the holes that fit then drilled and bolted the others and used huge washers. worked fine .</TD></TR></TABLE>
prob with that is the rears have those humps and if i line up the front, the backs just hang and where the rear sits onto is where the slider is, if i remember correctly
Old Nov 11, 2007 | 11:27 AM
H22AJSPEC's Avatar
Ya come to think of it it was super ghetto I had to shim the backs to level the seats out it .
Old Nov 12, 2007 | 05:38 AM
JDM-Punk's Avatar
up
Old Nov 12, 2007 | 05:44 AM
OnePointFive's Avatar
overrated.
here's a good writeup
http://battlecat.8m.com/DelSols_install.htm
Old Nov 12, 2007 | 06:06 AM
teh hatton's Avatar
I did it in my DC. You have to switch the mounts and brackets from the DA onto the del sol seats. Its kind of a pain. I think I spent maybe 3 hours total on the whole project and I did it buy myself.
Old Nov 12, 2007 | 07:34 AM
db1b18c's Avatar
Use the write up on the battlecat site. I have done this seat swap 2 times. It is definitely NOT just a swapping rails kind of project. My first set took me nearly 12 hrs of fabbing and mock up. FOLLOW the instructions step by step as I was the one to help make some changes to make that write up NEARLY seamless and flawless.
You really need to have a GOOD drill and drill bits when starting this. DEFINITELY an air chisel would be cool too. TRUST ME.
Old Nov 12, 2007 | 03:42 PM
JDM-Punk's Avatar
Default Re: (teh hatton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teh hatton &raquo;</TD></TR><TR><TD CLASS="quote">I did it in my DC. You have to switch the mounts and brackets from the DA onto the del sol seats. Its kind of a pain. I think I spent maybe 3 hours total on the whole project and I did it buy myself.</TD></TR></TABLE>
dc's and da's have dif mounting styles, not possible to just swap the mounts and brackets, cuz thats what i thought it was going to be
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnePointFive &raquo;</TD></TR><TR><TD CLASS="quote">here's a good writeup
http://battlecat.8m.com/DelSols_install.htm</TD></TR></TABLE>
thank you ... haha i get to skip part 2...cdn model ftw
Old Dec 18, 2007 | 04:39 PM
JDM DERF's Avatar
will this work for any seats or just del sols?
Old Dec 18, 2007 | 04:51 PM
JDM-Punk's Avatar
Default Re: (JDM DERF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM DERF &raquo;</TD></TR><TR><TD CLASS="quote">will this work for any seats or just del sols?</TD></TR></TABLE>
what seats you trying to put in it?... the del sol seats mounting points are the same design as the eg/ek/dc (i believe) so i would imagine it would be the same
Old Dec 18, 2007 | 05:49 PM
JDM DERF's Avatar
a friend of mine has some jdm ek seats (but im guessing there the same as usdm) for sale and i was thinkin about pickin them up
Old Dec 18, 2007 | 06:22 PM
JDM-Punk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM DERF &raquo;</TD></TR><TR><TD CLASS="quote">a friend of mine has some jdm ek seats (but im guessing there the same as usdm) for sale and i was thinkin about pickin them up</TD></TR></TABLE>
i am very sure its the same deal with the sol seats... but have no personal experience with them
jeffnerette
12
Nov 25, 2008 05:52 AM
Nysh
Aug 2, 2007 03:33 PM
Civic97s
Mar 23, 2006 06:35 PM
dawrenn
Mar 30, 2005 07:23 AM
JDM_lover03
16
Sep 19, 2004 11:13 AM
