11" slotted rotors with 4x100?
There is probably a simple, easily found, straightforward solution to my query, but I can't seem to find it anywhere.
I recently added Integra rear disk brakes to my 96 coupe and the next step is to use the Integra calipers for the front, and using a Fastbrakes caliper bracket, fit them over 11" rotors. Because of a pretty pathetic brain fart, I had just planned on hunting down some replacement, slotted Integra R rotors. Whoops! Those aren't 4 lug. So my question is, who makes some reasonably priced, 11", slotted rotors for a 4x100 bolt pattern with the correct offset so I can use them on my Civic with Integra brakes?
Thanks.
Thanks.
the closest i can find was like 10 3/4 i think it was... but go check on
http://www.autopartswarehouse.com
http://www.brakeperformance.com
