Raising Exhaust Piping? (searched)
How is it possible to raise a cat-back exhaust using the rubber hangers? Are there other hangers that can be purchased to raise it all up? What do most people do in the event where their exhaust hangs too low?
P.S.
I've tried placing the exhaust hangers higher up (using the middle of the hangers), but I've still got a good 3" of room to bring it up some more. I'm really at a loss as to what I can do other than to cut and reweld the hangers on the exhaust so that it sits higher
P.S.
Do you know what a hanger is?
Well if you examine your exhaust pipe they are these little rubber pieces attached to the frame and the exhaust pipe. You can bend the metal piece that connects to the rubber piece, or do a zip tie, on your hangers. I recommend you dont use plastic zip ties, you find one made of metal.
You have one in the front on your down pipe.
2 behind the cat, 2 more a little further down and 2 holding your muffler on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 »</TD></TR><TR><TD CLASS="quote">Do the rubber hangers melt?</TD></TR></TABLE>
lmfao!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker »</TD></TR><TR><TD CLASS="quote"> But yeah bend your hangers to achieve this</TD></TR></TABLE>
try it
lmfao!
try it
Yeah, I know what/where the rubber hangers are.
So you suggest I bend the arms that hold them to the frame? That and/or use zip ties to hold the exhaust up instead...
I'll give it a shot this afternoon.
would it not be easier to ziptie the exhaust's hangers to the metal hangers on the frame (using multiple ties)? or would that cause too much vibration
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">ziptie the rubber bushings to make them smaller....</TD></TR></TABLE>
try it
plus if you mess up hey arent that expensive to replace. i think they like 5 bucks or somehtin on majestic honda
try it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_93vtec »</TD></TR><TR><TD CLASS="quote">
try it
plus if you mess up hey arent that expensive to replace. i think they like 5 bucks or somehtin on majestic honda</TD></TR></TABLE>
i've already done it....
cusco also makes hanger bushings
try it
HT Chaplain
Welding / Fabrication
Jan 22, 2008 04:21 PM
