inner joint for b16a2 - fits from other engine ?
I need a inner joint ( the head that enters into gearbox from the short axle ) and where i live i can't find something like that,just the one that enters into wheel and there are no b16a at junkyards.
You think that it will fit from any other engine that maybe i can find at the junkyard ?
I can't move my car after the swap...
How you open the hood the left side,there is the short one that enters into wheel and in the other part enters the trasnmission.I think that's the inner joint right ?
So the right one,that's the one that enters into trasmission.
From b16 i know they work,i meen from some prelude or older/newer civic or i don't know maybe from some VW or ****,that i can find here at the junkyard.
I need the right axle,the hole axle like in this picture,or just that head that enters into transmission.So you think the head of the axle should have the same diameter from a b20 engine from prelude or somethink like that ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cioli »</TD></TR><TR><TD CLASS="quote">Even from prelude,b20 ??????</TD></TR></TABLE>
no b20 half shaft wont fit.i tried that before. only 94 up integra..LS/GS/GSR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cioli »</TD></TR><TR><TD CLASS="quote">Inner joint from d16z5 removed and fitted on the b16a2 axle,works perfect.
d series does not have a half shaft axle
The inner joint i took it from passanger side axle from crx non-vtec,that engine too had that half-shaft axles on the other side ( driver side ),but i took the passanger side inner joint and i fitted on my b16a2 axle that i was missing the original inner joint.
