Installing Skunk2 GSR intake manifold (pro series) where do lines go?
Old Nov 11, 2007 | 01:44 AM
Civiclx's Avatar
Default Installing Skunk2 GSR intake manifold (pro series) where do lines go?
where do the lines on the EVAP control go? I have one going to the charcoal canister and where does the other go? also, on the back of the intake manifold, if you are looking at the lower right of the flange, there is a big brass hole, i know that is for the coolant, but there is a little one next to it. what goes there? Thanks!
Modified by Civiclx at 10:09 AM 11/11/2007
Old Nov 11, 2007 | 06:43 AM
projectcivicjp's Avatar
Default Re: Installing Skunk2 GSR intake manifold (pro series) where do lines go? (Civiclx)
do a search in the acura integra forum and search blox intake manifold and read up.The S2 and blox are basically the same mani. I wanna say its an extra coolant port, you can just plug that with some JB weld or something but I'm not sure.
Old Nov 11, 2007 | 08:05 AM
zerovandez's Avatar
On an OEM GSR intake manifold for obd2 motors, there's a purge solenoid that sits on top of it. One vacuum line from the manifold connects to it, then another line going to that same sensor comes from the charcoal canister.
Old Nov 11, 2007 | 02:08 PM
Civiclx's Avatar
Default Re: (zerovandez)
so on the skunk2, the purge solenoid does not have a place to do, where can i mount it and where do i get the vacuum from? i know the other side goes to the charcoal canister. Thanks folks!
Old Nov 12, 2007 | 08:22 PM
all-mtr-teg's Avatar
Default Re: (Civiclx)
just zip tie the purge solenoid to the firewall somewhere, and the evap vacuum hose can be T'ed to the pcv valve hose.
DC4_Dad
Aug 16, 2018 10:16 AM
OOOtony
Feb 17, 2010 11:36 PM
jkalex05
Aug 23, 2009 06:01 PM
dx2sicrx
May 29, 2008 08:20 PM
mike34655
Aug 23, 2003 04:07 AM
