FS: Civic & Integra parts ( ecu, oil relo kit, canton mecca filter, mocal thermostat, rear disc swap
Old Nov 10, 2007 | 09:50 PM
FuNkDrSpOt's Avatar
Default FS: Civic & Integra parts ( ecu, oil relo kit, canton mecca filter, mocal thermostat, rear disc swap
<FONT SIZE="2">Notables:</FONT>
<FONT COLOR="maroon">- My vouch/transaction history is at the bottom of this post or in my main FS thread, which can be found in my sig</FONT>
<FONT COLOR="purple">- Don't like a price? Make me an offer! I just tell you yes or no in a professional manner. Prices DON'T include shipping. I ship from the 95865 zip code. </FONT>
<FONT SIZE="3"><FONT COLOR="blue">---For Sale:---</FONT></FONT>
'98 Integra Gsr Ecu - $100
Working unit that was never tampered with but unfortunately since my particular civic doesn't have an FTP sensor i had to use a '97 ecu to BAR-certify my engine swap.
Canton Mecca 6" oil filter/filter replacements/ring kits/etc - $140
Hi-flow oil filter that doesn't have a bypass ( when you're in vtec ) AND filters down to 8 microns. Filters are good for 12k miles each.
MF Factory oil block adapter - $40 - top left
MF Factory oil filter adapter - $40 - top right
oil inline block adapter for oil sensors- $40 - bottom right
Good for oil fliter relocation, oil sensors and oil cooler projects projects.
MF Factory 10AN braided oil lines - $30
Ended up being too short for my use.
'98 Integra trailing arms w/ABS sensors & Integra E-brake cables - $175
I'm selling my car to my mom and she doesn't care about rear disc brakes.
Fastbrakes.com '94-'01 integra / '92-'96 civic rear braided brake lines - $65
Fastbrakes.com '96-'00 Civic Ex front braided brake lines - $65
Civic Si ( '99-'00 ) e-brake cables - $80
Civic Si ( '99-'00 ) 4040 prop valve - $80
Misc clips needed for a civic rear disc conversion - $10
As you can see they're ALL brand new and in sealed honda bags. I'm selling my car to my mom and she doesn't care about rear disc brakes.
Boomslang obd2a E-manage Ultimate Harness - $180
I was gonna turbo my swapped civic but now the turbo is going to the new integra, which is Obd2b @ me
Alpine Type-S 10" bandpass enclosure model# Sbs-1041bp 10 - $170
It came with the new Integra that I bought and I have no use for it because I have a 12" Infiniti Kappa Perfect that I'll be making a fiberglass enclosure for. Looks brand new.
A crutchfield.com review
100% custom 12" sub box/trunk setup for '96-00 civics (sub not included) - $400
This is a custom setup I paid Paradyme $800 to make. It is designed for a 12" sub to go against the back seat and for an amp on each side. All you have to do is add your own sub and screw it in since it's already precut. Note, my car was a '97 Civic 4dr so I'm ASSUMING that all civic trunks are the same.
1 Kumho Ecsta Asx - $50
Brand new spare tire. Came with the new car.
Konig Holes 16x7 w/ Pirelli P Zero Nero M+S 205/50/16 tires. - $500
4x100 bolt pattern - 16lbs per rim - 40mm offset
Essentially brand new. They were on my ex's civic for around 4k miles before it was totaled. They were kept in storage since. There is only one small imperfection in 1 rim. The tires have somewhere between 80%-90% tread left.
Rim #1
Rim #2
Rim #3
Rim #4
tread pic
'02 Civic Hub caps - $40
2 look brand new, 1 has light scratches, 1 has light/moderate scratches
'96 - '00 civic dual gauge bezel - $30
Brand new.
'97 Integra Gsr jdm intake mani w/o sensors - $40
Perfect for those of you who want an intake mani to bore out, or if you're already OBD 1.
'97 Civic Power Steering pump w/AEM underdrive pulley (93k miles) - $40
Was taken out along b/c of in engine swap.
94 - 01 Integra Power steering belt. Brand New - $20
'97 Integra Gsr Jdm power steering pump - $40
It came with my engine swap.
'97 Integra charcoal canister - $40
'97 Civic charcoal canister - $35
PIAA fog lights, mounting brackets and fog light electrical harness - $50
One of the fog lights does not screw all the way closed and had to be taped shut but they still work.
Civic seat belts and seat trim and other misc parts - $20
'97 Integra JDM vtec solenoid - $50
Should work with OBD1 cars, as far as I know
<FONT SIZE="3"><FONT COLOR="blue">---Sale History:---</FONT></FONT>
Honda-Tech.com sales:
99-00 Honda Civic charcoal canister - sold to jo@ko
D16y8 alternator - Sold to SoullessJapaneseMachine
Ej8/Dc2 Brembo crossdrilled rotors - sold to Outkast95LS
Tein H-tech Springs for 96-00 Civic - Sold to i_drive_an_eh
EJ front seats - Sold to 95DxSi-R2
'98 jdm GS-R B18c P72 ecu - Sold to xdr3amx
'97 B18c Jdm wiring harness - sold to 95 integra
D16 14'' steelies - sold to CheEsEsTeAk168
'97 D16y8 block - sold to The brown kid
AEM V2 CAI - sold to Laserjock
B series vtec solenoid - sold to Akiraboy
Gs-r door panels/vtec solenoid - sold to gotboostedvr6
P30 A/C Bracket - Sold to Vita-Soy
D16 crankshaft pulley - sold to galaxykid70
D16y8 97' head & ecu - Sold on Ebay to DjBiamme
D16 DC Sports Stainless Steel 4-2-1 header - sold to 1cleanej8
D16 oil pan - sold to G U E C O
D16 tranny - Sold to Cpt Ben
D16 Exedy stage 1 clutch - sold to Ron burgandy
D16 axles & shift linkage sold to CRX_Phantom1
DC Sport Short shifter - sold to chsamia
D16 starter - Sold to Tarzjdm
Other sites:
Mocal oil thermostat - Sold to JRutski @ team-integra.net
Rear NSX calipers w/Hawk Brake Pads - Sold to GotBHP? @ nsxprime.com
d16 alternator, flywheel, water & oil pump - Sold to Vinnie on Craiglist
Gsr rear seats - Sold to Sebastian on craiglist
'97 Gs-r seat rails - sold to Peter on Craigslist
Arospeed 17''rims/Michelin PE2 tires - Sold to Mike on Craigslist
Modified by FuNkDrSpOt at 5:54 PM 11/17/2007
Old Nov 11, 2007 | 07:33 PM
FuNkDrSpOt's Avatar
Default Re: FS: Civic & Integra parts ( ecu, oil relo kit, canton mecca filter, mocal thermostat, rear disc
blah!
Old Nov 13, 2007 | 07:06 AM
FuNkDrSpOt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">Bump pirate says "To the Top, yar!"</TD></TR></TABLE>
Old Nov 16, 2007 | 01:17 PM
FuNkDrSpOt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">blah!</TD></TR></TABLE>
Old Nov 22, 2007 | 12:01 PM
FuNkDrSpOt's Avatar
Old Nov 23, 2007 | 04:05 PM
FuNkDrSpOt's Avatar
Old Nov 24, 2007 | 12:01 PM
FuNkDrSpOt's Avatar
Old Nov 28, 2007 | 02:40 PM
FuNkDrSpOt's Avatar
Old Dec 4, 2007 | 11:08 AM
FuNkDrSpOt's Avatar
nicholasellin
Honda Civic (2001 - 2005)
May 6, 2014 09:52 AM
laloquera916
Sep 9, 2012 08:52 PM
3s0n3
May 4, 2006 04:06 AM
daman895
Dec 12, 2002 03:21 PM
hadookn
Apr 28, 2002 10:01 AM
