loose of power when cruising.
Old Nov 10, 2007 | 04:41 PM
hedtrip's Avatar
Default loose of power when cruising.
i havn't been able to figure it out. it doesn't do it all the time. usally when i've been driving for awhile.
but when im just crusing it will just loose power as if it's not getting gas or spark. so i have to push the pedal to the floor & it go's fine again.
i've tryed a diff fuel pump & main relay rechecked all my wires & vacum hoses.
would a bad injector or dizzy cause this? anyone have the same problem ?
btw it a 92 DX
Old Nov 10, 2007 | 04:45 PM
JDMTurboEG6's Avatar
Default Re: loose of power when cruising. (hedtrip)
im havin the same problem
Old Nov 10, 2007 | 04:54 PM
hedtrip's Avatar
Default Re: loose of power when cruising. (JDMTurboEG6)
other then that the car drives great. it's not throwing any codes
Old Nov 11, 2007 | 04:54 AM
hedtrip's Avatar
no1 know ?
Old Nov 11, 2007 | 05:19 AM
hall97civic's Avatar
Default Re: (hedtrip)
not if you aren't throwing codes. I had the same problem with my hx, but it was throwing random misfire codes. It ended up being the egr plenum was plugged up and full of carbon.
Old Nov 12, 2007 | 05:22 AM
hedtrip's Avatar
im thinking about trying a diff dizzy 2day
Old Nov 12, 2007 | 05:27 AM
B16B_coupe's Avatar
HRD PKR
how do your plugs look? cap and rotor?
Old Nov 12, 2007 | 07:50 PM
Default Re: loose of power when cruising. (B16B_coupe)
there all new it only acts up intermittently cant figure it out
Old Nov 15, 2007 | 03:06 AM
hedtrip's Avatar
mine are new to
Old Nov 15, 2007 | 03:18 AM
hedtrip's Avatar
what all have u tried?
Old Nov 16, 2007 | 05:00 PM
hedtrip's Avatar
i think i fixed it. i changed out the ecu.
Old Nov 16, 2007 | 05:08 PM
ocJDM4dr's Avatar
I had the same problem and i changed the ECU its good now....
austinkli
Jan 8, 2014 08:27 AM
PR8urVtec
Jan 14, 2011 06:34 AM
Fo-Do Fanatic
Apr 18, 2010 11:32 PM
123HondaFan
Oct 28, 2009 05:58 PM
EJ8VTEC
10
Jun 13, 2006 10:32 AM
