Who knows the answer to this wiring question?
Hello fellow drivers of the best car ever made by Honda, ever...
PROOF:
Anyway, I had a remote start setup I got from a trade and wired it up...found that it also has keyless entry, so why not?
I bought some keyless door handles, and have solenoids for the power locks. My question is, how do I get the wire through the OEM rubber tube to go from the door to the chassis? What do I have to do to get to the opening in the cabin?
I'd really appreciate the help. I've searched through threads on power window installations to see if I could source some information and haven't had any luck. I'd like to get it done before the upcoming paintjob and turbo z6 swap
Thankz0rz
PROOF:
Thankz0rz
just cram the wires in there! its tight I know, look for the other side of the grommet under the dash.
good luck
good luck
Thanks for the quick response. I've contorted my body and stuck my head under the dash, and could not find where the wiring comes through. What crap needs to be removed?
CRXFTW
CRXFTW
when you open the door, there is like a pin holding it from opening any further. remove the pin and open the door wider, you will find it more easier to work your wire there.
try pulling the grommet out and put a light on the outside, then look for the light from the inside.
and if you pull the pin out of your door (to open it up farther) be carefull not to open it too far cause you can crush your fender.
KYRGYZ
Mar 25, 2013 11:33 PM
dem0nk1d
Oct 20, 2006 04:37 PM
travelor101
19
Nov 11, 2005 06:18 AM
SiMateoAko
17
Aug 8, 2005 08:45 AM
