Speedometer Question
Old Nov 10, 2007 | 03:58 PM
roachsboosted16's Avatar
Default Speedometer Question
well i got the stock 0-130mph civic dx speedometer. i see the eg and ek meters goto like 140 or 160 or sumpthing. if i replaced mine with on of those, would i have to adjust the speedsensor in the tranny or adjust anything else, or would it function correctly if i slapped it on and went big?
Old Nov 10, 2007 | 04:11 PM
Hardedge's Avatar
Default Re: Speedometer Question (roachsboosted16)
What do you plan on doing with the car, because all speedometers already go quite a bit higher than their actual top speed (stock). If you're not going to be exceeding your gauge's reading in speed then it's just a ricer thing to do.
Old Nov 10, 2007 | 04:17 PM
Default Re: Speedometer Question (Hardedge)
yes my car goes just under 130, but i need some room bcuz i plan on going faster
Old Nov 10, 2007 | 04:22 PM
black_EM1's Avatar
Community Builder
Community Influencer
Why?
Old Nov 10, 2007 | 04:24 PM
BlueIntegraBoy's Avatar
None of the USDM EG clusters go past 130 MPH. The only USDM EK cluster that goes past 130 is the Si EM1 cluster. If you can get ahold of a UKDM Civic cluster, the speedos go up to 140 MPH for all models.
Old Nov 10, 2007 | 04:33 PM
Default Re: Speedometer Question (BlueIntegraBoy)
thank you, but wude i have to modify anything? or could i put it in and it would work?
Old Nov 10, 2007 | 04:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roachsboosted16 &raquo;</TD></TR><TR><TD CLASS="quote">thank you, but wude i have to modify anything? or could i put it in and it would work?</TD></TR></TABLE>
Just put it in and it will work
Old Nov 10, 2007 | 04:48 PM
You'll be looking for this....
Mike239
19
Apr 22, 2011 02:41 PM
hold your breath
Apr 5, 2008 11:33 PM
boost and bass
Dec 12, 2007 10:41 AM
Dly989
Nov 1, 2004 08:42 PM
djtrini
16
Nov 1, 2004 06:05 AM
