MIsfire at idle. not the traditional problem
i have replaced cap rotor plugs wires and still the same problem.
My car has a slight misfire at idle. the timing marks are dead on. It doesnt throw a code at all. If i hook up a timing light to each wire they fire fine except for #3. #3 flashes pretty crazy unless i pull the conector out of the dizzy until i can see the spark then it runs fine. plug it back in, same story.
It idles very rough until the car idles itself up and then slowly comes back down and does it again and again.
could it be a bad coil?
PS
bd2 b-series on S300
PS
bd2 b-series on S300Thread
