Ok, what did I just screw up?
Old Nov 10, 2007 | 01:43 PM
borat's Avatar
Default Ok, what did I just screw up? (car won't start)
I was redoing the grounds to my wideband, and when I had everything back in place, the car won't fire. The CEL is on, the engine turns over, but it won't start. Some things I've noticed:
-the PGMFI relay only clicks once
-I tried to pull the codes, but there isn't one stored
What I just found out went wrong was that I accidentally grounded the ECU power input (OBD1 pin A25) through the SRS unit ground . What would this mess up? Would the car still start if I fried the SRS unit? Would it fry the PGMFI relay?
Old Nov 10, 2007 | 01:55 PM
Hawkze_2.3's Avatar
Default Re: Ok, what did I just screw up? (borat)
You touched the power input wire to the frame at the SRS grounding point? That would make whatever fed power to the ECU at that point send the power to the frame (instead of the ECU)....possibly shorting out wherever that power was coming from. Check fuses and trace that wire to look for problems. Hope that helps...
Old Nov 10, 2007 | 01:57 PM
mgags7's Avatar
Good call hawk. I bet the 10A fuse under the hood is blown, I think its the clock/radio one or something, I don't remember fully.
Old Nov 10, 2007 | 02:07 PM
borat's Avatar
Default Re: Ok, what did I just screw up? (Hawkze_2.3)
Good call. According to this: http://www.superhonda.com/foru...17405 A25 gets power from the main relay. Any idea what fuse that would be fed to/from? God, I'm so pissed at myself right now.
Old Nov 10, 2007 | 02:08 PM
Hawkze_2.3's Avatar
There shold be diagrams of the fuses inside the fuse box....or you can just look for a blown one
Old Nov 10, 2007 | 02:10 PM
Acidcrakker's Avatar
Look under the drivers side fuse box. I remeber when i did my relay I blew a fuse under there
Old Nov 10, 2007 | 02:32 PM
borat's Avatar
Default Re: Ok, what did I just screw up? (Acidcrakker)
All the fuses are fine, damn. Guess I have to check the PGMFI relay now.
Old Nov 10, 2007 | 03:14 PM
mgags7's Avatar
So you say the CEL is on but no codes flash?
What other wiring did you mess with? It sounds to me like you have a major ecu problem. Check for voltage at that pin that you messed with.
Old Nov 10, 2007 | 03:26 PM
borat's Avatar
Default Re: (mgags7)
Fixed it! While going through the troubleshooting for the main relay it turned out to be... a fuse that I somehow missed .
Today's lessons:
-triple check your wiring when messing with ECU wires
-check every fuse before going through the pain of pulling and testing the main relay
Thanks to those who chipped in.
jrp355
Oct 19, 2011 07:49 AM
chyanok92
Jun 3, 2011 03:42 AM
Noldogg
Nov 1, 2010 09:02 AM
Hatchback of Notre Dame
Feb 5, 2006 10:52 AM
Andyb22g
Dec 28, 2004 12:53 PM
