stupid things always happen to me.
Old Nov 10, 2007 | 09:48 AM
frankenstienEk's Avatar
Default stupid things always happen to me.
Got a huge problem, yesterday i was washing my car, just about done when i decided to start the car for a little cruise. I Poped the hood to give the engine bay a quick wipe down as the car warmed up. Started to hit up different spots when i came across the left strut bar with the rag, all of a sudden the rag wrapped around the cam gears and the car completely shuts off. At this point am freaking out because i know it not good. So i take my valve cover off to unwrap the rag thats caught in the cam gears and try to crank it up but nothing, all it dose is start but it sputters off. Hopefully my timing belt just jumped some teeth and not bent valves. If anybody can possibly help me out on what happened that would be great.
Old Nov 10, 2007 | 10:07 AM
posHonda's Avatar
If the timing belt did skip a tooth you might have some bent valves.
Old Nov 10, 2007 | 10:39 AM
all-mtr-teg's Avatar
Default Re: stupid things always happen to me. (frankenstienEk)
That's why you shouldn't work on your car while it on, unless your diagnosing something. I had a buddy who tried tightening a timing belt cover bolt while his car was on and damn near had his arm ripped off when his shirt got caught on the power steering belt.
Old Nov 10, 2007 | 10:49 AM
Rickdrizzle's Avatar
wow, that's scary **** right there.
Old Nov 10, 2007 | 10:54 AM
b20quang's Avatar
Default Re: (Rickdrizzle)
Old Nov 10, 2007 | 11:44 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (b20quang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankenstienEk &raquo;</TD></TR><TR><TD CLASS="quote">
hahahah seriously WOW
might as well just have peed in your oil filler
Old Nov 10, 2007 | 11:57 AM
Default Re: (GRAF-FITI)
alright guys , i know it sounds irresponsible and newbish but it was just a quick run buy with the rag, i wasent getting into cracks and creases and leaning over the motor. By the looks of it, my cam gears aren't lined up so am hoping its just the timing but i can't find out till Monday to bring it to a shop
Old Nov 10, 2007 | 12:22 PM
Default Re: (frankenstienEk)
Good luck, i've seen cracked blocks due to timing belts that jumped
Old Nov 10, 2007 | 12:40 PM
Default Re: (all-mtr-teg)
Yea, but i think that would only happen if i was driving it. hoping because i was only at idle, i have a chance of nothing being damaged.
Old Nov 10, 2007 | 12:46 PM
Yeah, that is the extreme, most of the time just bent valves. My block cracked cause my belt slipped a tooth while in vtec
Old Nov 10, 2007 | 12:49 PM
b20integrapower's Avatar
this reminds me of that post a while back where the guy had pictures after his fingers got caught in the cam gears. Ill try to look for it. In case i do get it up. its disturbing and not safe for work.
Old Nov 10, 2007 | 03:01 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (b20integrapower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">this reminds me of that post a while back where the guy had pictures after his fingers got caught in the cam gears. Ill try to look for it. In case i do get it up. its disturbing and not safe for work.</TD></TR></TABLE>
Here is the post (severed finger pictured):
https://honda-tech.com/zero...50514
That is certainly a serious injury.
OP, since the gears are not aligned, you most likely skipped some teeth. I would not run the car, i.e. tow it to the shop.
Old Nov 10, 2007 | 03:12 PM
posHonda's Avatar
holy **** that finger is sick...
I dont think Im ever going to install any cam gears or replace a timing belt myself anymore.
Old Nov 10, 2007 | 03:34 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (posHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by posHonda &raquo;</TD></TR><TR><TD CLASS="quote">I dont think Im ever going to install any cam gears or replace a timing belt myself anymore.</TD></TR></TABLE>
Why not? Just keep safety in mind. If the engine is running, stay clear.
Old Nov 10, 2007 | 06:13 PM
DAturbo's Avatar
Def bent the valves samn thing happend in my talon not that i want to mention the car but i have a da now and learned from mistakes send the head out
Old Nov 10, 2007 | 06:35 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: stupid things always happen to me. (DAturbo)
isnt that like workin on cars 101, shut the **** off before workin on it...
Old Nov 10, 2007 | 07:21 PM
angelzhope720's Avatar
wow
Old Nov 10, 2007 | 08:50 PM
Default Re: stupid things always happen to me. (stocker2shocker91)
Yes you would, unless your actually trying to diagnose something or set the timing, etc, but never leave it one when you rubbing the motor or engine bay down, especially near belts and hot parts.
94cxhatch
Nov 8, 2010 03:17 PM
_kiid
Sep 7, 2009 06:52 PM
VSBB6
Aug 17, 2005 08:32 AM
VSBB6
Aug 13, 2005 01:17 AM
RacerZook
Jan 5, 2004 07:36 PM
