Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
VTEC Question
Old Nov 10, 2007 | 09:04 AM
scca-racerx's Avatar
Default VTEC Question
Is it possible to lower, rpm wise, when the VTEC kicks in? Mine kicks in around 6k. Is it possible to lower it to 5k to get more power sooner? Would this be an electronic change or mecanical? Or would it be impossible? Thanks for your input.
07 Galaxy Grey Sedan.
Old Nov 10, 2007 | 09:08 AM
24boosted's Avatar
Default Re: VTEC Question (scca-racerx)
http://www.hondata.com, use the search function please. Keep your flame suit on.
Old Nov 10, 2007 | 09:21 AM
SIVIC 3's Avatar
apex-i vafc
Old Nov 10, 2007 | 09:40 AM
originalg00kster's Avatar
Default Re: (SIVIC 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIVIC 3 &raquo;</TD></TR><TR><TD CLASS="quote">apex-i vafc</TD></TR></TABLE>
apexi does not work for our cars so dont listen to this guy.
we have no v-tec controller
piggy backs dont work for us
only way to answer your question is what 24boosted said
get the reflash
Old Nov 10, 2007 | 10:18 PM
Zavala07si's Avatar
Default Re: (originalg00kster)
...the neo is your best bet.
Old Nov 11, 2007 | 09:13 AM
SIVIC 3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by originalg00kster &raquo;</TD></TR><TR><TD CLASS="quote">
get the reflash</TD></TR></TABLE>
i was just telling him what can change a vtec engagement point
Old Nov 11, 2007 | 01:25 PM
24boosted's Avatar
Lowering Vtec won't do anything unless it's tuned. If your just going to lower it without a proper reflash it's not going to go well with the ecu.
Old Nov 11, 2007 | 01:32 PM
elohel's Avatar
Default Re: VTEC Question (24boosted)
Even if you could it wouldn't matter, because Hondata has already said having a lower vtec engagement without some simple bolt-ons will LOSE power. I guess there's a reason Honda didn't put it at 5k.
Personally.. I think the SI would be near-perfect if they had reworked the intake or exhaust a bit and lowered it down to 4k. I feel that's the SI's biggest problem in terms of performance - it just feels so weak below 6k, and then 6k-8k is over in a blink. Plus I try not to shift right at redline and most always fall out of vtec on the next shift.
Old Nov 11, 2007 | 02:25 PM
accordselux's Avatar
Me Gusta History
i was just telling him what can change a vtec engagement point </TD></TR></TABLE>
Which would be a waste of money because it doesn't work on the 06+ Si.
Old Nov 11, 2007 | 02:41 PM
RICO_'s Avatar
NO MERCY!
Default Re: VTEC Question (elohel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elohel &raquo;</TD></TR><TR><TD CLASS="quote"> I feel that's the SI's biggest problem in terms of performance - it just feels so weak below 6k, and then 6k-8k is over in a blink. Plus I try not to shift right at redline and most always fall out of vtec on the next shift.</TD></TR></TABLE>
Yes but you're forgetting one very important thing. Yes the car is weak below 6K, but it's for a reason. It was designed to utilize a unique combination of fuel economy and high power output at the upper RPMs. Which is where VTEC comes in.
And while the car is weak below 6K rpms, when you're in an all out race....unless you shift early....you'll always be in that 6K or above RPM range if you shift right at red-line. So the car will continuously pick up speed. The only real place the Si is lacking in terms of acceleration is off the line.
Old Nov 12, 2007 | 05:02 AM
jaepalm's Avatar
Default Re: VTEC Question (RICO_)
Amen. With our cars, its really all about the launch. If you race that is...
Old Nov 12, 2007 | 05:22 AM
IT GUY's Avatar
Default Re: VTEC Question (jaepalm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaepalm &raquo;</TD></TR><TR><TD CLASS="quote">Amen. With our cars, its really all about the launch. If you race that is...</TD></TR></TABLE>
dude, the op's name is SCCA-Racerx right? launching well probably doesn't improve his times much since he isn't going in a straight line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zavala07si &raquo;</TD></TR><TR><TD CLASS="quote">...the neo is your best bet. </TD></TR></TABLE>
nope.
Hondata is really your only option to achieve your goal correctly. Like someone mentioned before, you will need a minimum of Intake OR Header/exhaust to see gains from the reflash, but you don't need all 3, i/h/e, to run the reflash.
like 24 boosted mentioned, do a little searching. you'll see how well the reflash works for these cars.
Old Nov 14, 2007 | 08:09 AM
Default Re: VTEC Question (IT GUY)
Thanks to all that replied. I will not be going in a straigt line. Drag racing is for fast cars - auto crossing is for fast drivers. To stay in GS I can not change my intake or my header, so lowering the vtec won't do me any good. All I can change is the air filter and anything from the cat back.
Thanks for the info.
Old Nov 15, 2007 | 12:58 PM
FG_Coupe's Avatar
Default Re: (Zavala07si)
Hondata Reflash is your best bet...it gives you a Vtec window from 4500-thru 5800 and gain midrange power,and it also increases your rev limiter up to 8600...with a combination of an race header and an CAI...i can almost assure you that you would gain quite a bit of power...go to http://www.hondata.com
BLUIZE256
Nov 2, 2007 10:04 PM
tigueremalo
Sep 20, 2006 03:32 PM
nikboca
Honda S2000
10
Mar 31, 2006 10:14 AM
bja2704
Oct 22, 2005 01:01 PM
djay86
Dec 27, 2003 03:39 PM
