Suspension & Brakes Theory, alignment, spring rates....
what is the difference?
Old Nov 10, 2007 | 08:40 AM
SpeedoKing's Avatar
Default what is the difference?
ok so i know this is kinda a n00b question but ill ask it anyways. i have a 99 civic ex coupe and i was looking to lower it i was going to go with koni yellows on H&R spot springs but yesterday i found some koni coilovers that have this exact set up for $8XX which seem fairly reasonable. So my question is what are the pro and cons of coilovers and buying the shocks and springs individually? which is better?
Old Nov 10, 2007 | 09:34 AM
SpeedoKing's Avatar
Default Re: what is the difference? (SpeedoKing)
anyone...? i jus wanna make sure im not going to wast my money on something that isnt worth it.
Old Nov 12, 2007 | 09:11 PM
PIC Performance's Avatar
So you found exactly the same thing, but one is cheaper? I'd get the cheaper one, the difference is one is less expensive than the other.
The only pros and cons in going with a separate spring/shock combo vs. a pre-packaged spring/shock combo (both are coilovers) is cost and convenience. For actual difference in reliability and performance, you'll have to analyze each individually as there are good and bad examples for both routes.
masijdm
Suspension & Brakes
Jul 5, 2008 12:09 PM
soundFX
Suspension & Brakes
Dec 30, 2006 11:01 PM
DC2_2
Oct 14, 2006 06:28 AM
undertheradar
Suspension & Brakes
11
Dec 16, 2005 10:01 PM
94TealCivic
Jul 10, 2003 01:49 PM
