correct offset for 16" wheels
Old Jun 23, 2002 | 08:27 PM
willyboyK20's Avatar
Default correct offset for 16" wheels
I plan of buying some 16 wheels in a couple of months for a 97 civic and I want to know what would be the right offset to get for it. I don't want to get a wheel that sticks out to much. What is the the offset of the stock wheels if anyone knows.
Thanks
[Modified by willyboyD16, 12:27 AM 6/24/2002]
Old Jun 23, 2002 | 09:01 PM
DigitalFusion's Avatar
Default Re: correct offset for 16" wheels (willyboyD16)
my old 16" enkei's had 38 offset.. the smaller the number the more they stick out if i remember right
Old Jun 23, 2002 | 09:07 PM
tonyxcom's Avatar
You should be fine with 40-45 offset and 205/45/16 tires.
The closer to 45 the better you will be if you are lowered a lot.
I have 40 offset and I had to remove the rubber trim in the rear fender.
Old Jun 23, 2002 | 09:12 PM
Default Re: correct offset for 16" wheels (tonyxcom)
what about 40 series sidewall? would that ride a little rougher than 45 series?
Old Jun 23, 2002 | 09:26 PM
a lil roughr, but nothing drastic.. if u have 16"s i would go for the 45
[Modified by CustomCockpits, 12:26 AM 6/24/2002]
Mike P.'s Avatar
25 Year Member
I would tend to think that the width of the wheel *might* be a needed dimension for one of us to tell you what you need.
Old Jun 23, 2002 | 09:28 PM
Default Re: correct offset for 16" wheels (Mike P.)
16x7
Old Jun 25, 2002 | 10:39 AM
qbsi's Avatar
just get 16' x 7 with a 42mm or 45mm offset.
if you get 40mm, you might notice a slight rubbing in the fronts and the rear depending on how low you go.
i have 40 offset on mine, and it rubs a lil with a 2 inch drop.
you'll be happier with a 42mm or 45mm, trust me.
Old Jun 25, 2002 | 10:42 AM
Default Re: correct offset for 16" wheels (qbsi)
thanks
elitesi8
Oct 13, 2006 11:52 AM
Uncle Jesse
Jul 13, 2006 07:33 AM
JDM_EK_JOE
Honda Civic (2006 - 2015)
Apr 7, 2006 05:18 PM
JunIntegra
Jan 24, 2004 11:20 AM
MikeD
Jul 24, 2001 09:05 AM
