header question
Old Nov 9, 2007 | 10:08 PM
CRX91SE's Avatar
Default header question
Ok i picked up a greddy 4-2-1 1 piece header, i have 2 o2 in my oem header. The greddy one only has 1 at the colecter. Im using a p30 ecu, cant i just use one o2?
Also im throwing a code for my o2 senser heater, does that mean that none of my o2's are working. Since its obd1 not obd0... Cause the pw0 looks for 2, and since i dont have the heater o2 its not finding it?...
So if i just instal the greddy will it run the same?..
-Chris
Old Nov 10, 2007 | 09:05 AM
spaceman's Avatar
Default Re: header question (CRX91SE)
there is a way of using just 1 i think...
i got the same header..i took it to a shop and had two bungs installed like stock and plugged the orignal o2 spot. make sure you get the right spots so the sensors will clear the block/head.
also when installing the 1 piece i had to lower/drop the front crossmember.
good luck
Old Nov 10, 2007 | 09:51 AM
CRX91SE's Avatar
Default Re: header question (spaceman)
i know i have to do that, its just im wondering if im actually using one o2. since non of them are heated and im throwing a code for a heated o2..
Modified by CRX91SE at 11:05 AM 11/10/2007
Old Nov 10, 2007 | 11:12 AM
crx_si-r's Avatar
well if ur runnin a P30 then u should also be running a 4-wire o2 sensor. are u running that one or a single wire o2 sensor?
Old Nov 10, 2007 | 04:38 PM
CRX91SE's Avatar
Default Re: header question (crx_si-r)
im running a sinlge wire o2, and there is 2 of them....
so if i install the header right it will be fine since im not using the right one? i dont need to get 2 bungs welded in...
And once i get the 4 wire i install it at the colector..
Old Nov 11, 2007 | 11:39 PM
CRX91SE's Avatar
ok i unplugged both of my o2 sensors, and my car is running the same. so i guess i can go ahead and install the greddy..
Now my next question, how do i intall the 4 wire o2 with 1 wire plugs... where do the extra wires go..
Old Nov 12, 2007 | 05:23 AM
M30B35's Avatar
the 4 wire o2 sensor is cake to install. http://mymiata.paladinmicro.com/Miata4-WireO2.htm has wiring info. the guys says he was expecting power gains. you will get none, its a sensor after all
Old Nov 12, 2007 | 09:32 AM
CRX91SE's Avatar
Default Re: header question (M30B35)
wicked! thanks alot... im installing my header today and doing the o2 sensor next weekend..
Thanks
Old Nov 13, 2007 | 08:25 PM
CRX91SE's Avatar
header was a bitch to get in, but all in all she's in there.. now i need more info on how to do my o2 sensor..
Like which wires go to where by my ecu..
i have a obd0-obd1 frog harness and im wondering if any go to the extra strad that you see here..
And i notice that my gas milage is really bad, since i have no o2 working..
Old Nov 13, 2007 | 08:27 PM
CRX91SE's Avatar
Old Nov 14, 2007 | 02:35 PM
CRX91SE's Avatar
TTT
Old Nov 16, 2007 | 04:56 PM
CRX91SE's Avatar
TTT?............
Old Nov 16, 2007 | 07:51 PM
4doorsleepr's Avatar
bahhh, O2 sensors are overrated, haha
Old Nov 17, 2007 | 10:04 AM
CRX91SE's Avatar
Default Re: header question (4doorsleepr)
no man i need gas milage spend 20 bucks a day on gas sucks ***
Old Nov 17, 2007 | 05:08 PM
CRX91SE's Avatar
I found this finally after searching for 2 days! With all my reciepts
Memnoch
Jul 16, 2009 07:20 AM
crxpwr1
13
Nov 26, 2007 12:29 PM
1320king
74
Feb 13, 2007 09:06 PM
VTECengaged
Jan 25, 2007 07:26 PM
Griffins_Importuning
Aug 4, 2002 01:15 AM
