no power to coil
i tried turning over my car the other day and it wouldn't turn over. i took a voltage meter to the coil and i wasn't getting any power to it so then i put on another dizzy and same thing it would turn over .so i am assuming that this is a problem in my wiring or could it be that both the the dizzys are shot? or could i have a short somewhere in the harness?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja »</TD></TR><TR><TD CLASS="quote">replace the coil and ignitor....if it's not one of those, and you've checked all of your fuses, then you better charge your battery.</TD></TR></TABLE>
here is a simple test to test the icm and coil unless your loaded with tons of money like this guy.
any time i hope this puts you in a direction of repair. i see a lot of people on here post for a problem withthe shot gun fix just replace everything and if that does not work then check this and that
. im sure they dont work on these for a living.
yea i pretty much wanna get to the bottom of this with minimum money spent.and i want to know what was the actual problem rathier then replaceing everything and never knowing.
well put i make no claim i no everything as im still learning all the time and very open to learn more. but since your car is stock from what i can see this is very basic and will provide you with more info if needed .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtapia »</TD></TR><TR><TD CLASS="quote">any time i hope this puts you in a direction of repair. i see a lot of people on here post for a problem withthe shot gun fix just replace everything and if that does not work then check this and that
Testing the coil and ignitor go without saying. But if you have enough parts laying around (I believe there are 13 distributors at my house) Then it is sometimes easier to just try a different coil or ignitor. And btw n00b, I have made my living working as a honda mechanic.
</TD></TR></TABLE>Testing the coil and ignitor go without saying. But if you have enough parts laying around (I believe there are 13 distributors at my house) Then it is sometimes easier to just try a different coil or ignitor. And btw n00b, I have made my living working as a honda mechanic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic »</TD></TR><TR><TD CLASS="quote">check fuses.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-meEj1 »</TD></TR><TR><TD CLASS="quote">already did and they are all good</TD></TR></TABLE>
ummm...just a question....how did you go about checking your fuses???
btw i tried two completly diffrent dizzy's. the first one is a dx dizzy and the other was a z6 dizzy. what is the probelity that both IMC's are shot in these?
</TD></TR></TABLE>[QUOTE=jz98ctr]
i see but you were telling the guy to replace it and if it didnt start then charge the battery ?? not sure what that is going to do it the battery is charged and turning over. do you still work for a dealer?. or some shop that throws parts at cars and hope it fixes them
</TD></TR></TABLE>[QUOTE=jz98ctr]i see but you were telling the guy to replace it and if it didnt start then charge the battery ?? not sure what that is going to do it the battery is charged and turning over. do you still work for a dealer?. or some shop that throws parts at cars and hope it fixes them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja »</TD></TR><TR><TD CLASS="quote">i work for your mom, she pays better.</TD></TR></TABLE>
thats right she works your *** on the streets like a beyatch. so get off the computer and get to work before she back hands you like the pimp she is.
* B A N N E D *
From: Running Round At Night In Los Angeles Like A Crazy, Veva Mexco, Veva Mexco
brixity
28
Jun 22, 2005 05:39 AM
