Wideband 02
Old Nov 9, 2007 | 06:56 PM
Hondacivic91dx's Avatar
Default Wideband 02
what company makes a good wideband o2 sensor that will go down to at least 10?
Old Nov 9, 2007 | 08:05 PM
Nick_S's Avatar
I have the aem wideband it works great for me.
Old Nov 9, 2007 | 08:28 PM
ef92b's Avatar
Default Re: (Nick_S)
http://www.innovatemotorsports.com/index.html
Old Nov 9, 2007 | 08:33 PM
sanimalp's Avatar
$cat /dev/urandom
10 is pretty freakin rich... i know i have been holding out for the innovate wideband myself, but there really are a lot of options as far as widebands go. The main issue you will run into with most widebands when you are trying to play around 10:1 is that the sensor does not generate a voltage below 10:1 AF. The most common cheap ($50-75) wideband 02 sensors simply dont work down there, so you might be looking at specialty equipment altogether, because most widebands under $300 are calibrated to work with the wideband sensor style represented by the graph below.
This map shows what i am talking about.
Old Nov 10, 2007 | 08:53 AM
crxfreak1117's Avatar
Default Re: (sanimalp)
i have the innovate lm-1 wideband and love it and it goes well belowe 10...
balbowskie
Jul 18, 2012 02:24 PM
D15JDMARIO
Mar 3, 2007 07:39 PM
Soccerking3000
Apr 21, 2006 10:14 PM
Trac226
May 8, 2003 11:40 AM
spike
Dec 10, 2002 08:14 AM
