Questions on lube...
Old Nov 9, 2007 | 02:47 PM
Hahnduh's Avatar
Default Questions on lube...
so I got my new act today!!! now I just have get some other little random stuff, gaskets MTF and such. Do you need to pack the release bearing or the pliot bearing at all?? what kind of lube do you use to grease everything down?? like high temp stuff or what I have wheel bearing grease but im not sure what to use.. any other stuff to replace while its all torn apart
Old Nov 9, 2007 | 02:58 PM
Frickr's Avatar
Default Re: Questions on lube... (Hahnduh)
if its a barring it will most likely be a roller barring, and the pins will already be packed in with grease. where as a bushing is a soft metel that doesnt need any kind of grease or anything.
Old Nov 9, 2007 | 05:11 PM
Hahnduh's Avatar
Default Re: Questions on lube... (Frickr)
wow seriously.....a barring
Old Nov 9, 2007 | 05:17 PM
1992Si's Avatar
Hey the guy's trying to help you...
Only put a light coat of high temp grease where the throw out bearing slides.
Don't put any grease on the rotating part of he throwout bearing. I also put a small amount of high temp grease on the splins that slide through the clutch disc.
Any excess grease will find it's way to the flywheel surface, not a good thing.
Old Nov 10, 2007 | 01:11 PM
Hahnduh's Avatar
Default Re: (1992Si)
well then high temp grease it is then, is this the same stuff that you can use on wheel bearings or what?? I was going to use some 80w-90 gear oil
Old Nov 10, 2007 | 01:15 PM
Eran's Avatar
HT White Ops
I use Urea Grease from Honda.
shyguy4no1
May 20, 2010 08:54 AM
crxpwr1
11
Oct 2, 2006 03:45 AM
lsvtec101
Jun 8, 2004 08:08 AM
TurblowR
May 19, 2004 07:41 PM
ScottEK
Mar 28, 2003 03:09 PM
