D to B series exhaust adapter
why would you want to connect such small POWER RESTRICTING pipe behind a motor that you swapped in for more power? go look at a CRV and see how much bigger their exhaust diameter is!! your going to create WAY too much backpressure which is going to kill your top end! get a catback or have one made at a local muffler shop, make sure you get 2 1/4" diameter or larger. it's not as expensive as you'd think to have one made. with the high flow cat I had one done for less than $300, and that's INSTALLED!!! just don't leave the stock pencil sized exhaust if you have a b motor!!!!
well thanks for the input, I just needed a cheap adapter for temporary so I can drive the car without making everyone deaf around me, im saving up for a HKS s1 cat-back so thats why I just wanted something cheap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudandlow »</TD></TR><TR><TD CLASS="quote">why would you want to connect such small POWER RESTRICTING pipe behind a motor that you swapped in for more power? go look at a CRV and see how much bigger their exhaust diameter is!! your going to create WAY too much backpressure which is going to kill your top end! get a catback or have one made at a local muffler shop, make sure you get 2 1/4" diameter or larger. it's not as expensive as you'd think to have one made. with the high flow cat I had one done for less than $300, and that's INSTALLED!!! just don't leave the stock pencil sized exhaust if you have a b motor!!!!
</TD></TR></TABLE> You make it sound like the world would end if he left the stock exhaust. BTW, top end is a relative subject when discussing a factory non-VTEC motor.
If you want something cheap, get an ebay header for a Del Sol VTEC, or a stock exhaust manifold/downpipe for a Del Sol VTEC. Either is a direct bolt-on. There is absolutely NO WAY to use a single cam manifold/header on a B20.
Modified by StorminMatt at 11:35 PM 11/11/2007
Civic|Ky
22
Aug 21, 2015 08:45 AM
superg6819
22
Jan 27, 2009 06:32 PM
uptownspeedstar
Jul 18, 2007 06:11 PM
