koni yellows on e-bay sleeves?
i currently have some e-bay 10k f 8k r coilover sleeves on stock shocks and rides like ****
extremely bouncy and rough, if i were to get koni yellows would my ride quality improve and will they fit on the shock? thanks fellas
had that before, you shocks are blowns thats why its bumpy, get kyb agx and it will be much better, but imo get rid of cheap sleeves, and get the springs better, of course you still need new shocks
yeah the shocks are blown, i can only afford 1 thing right now. would i be better off getting some ground control coilover sleeves and slap them on with the stock shocks, then get the koni shocks? or will this also cause problems on the coilovers since they will not be on the koni shocks for a while?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ware »</TD></TR><TR><TD CLASS="quote">yeah the shocks are blown, i can only afford 1 thing right now. would i be better off getting some ground control coilover sleeves and slap them on with the stock shocks, then get the koni shocks? or will this also cause problems on the coilovers since they will not be on the koni shocks for a while?</TD></TR></TABLE>
Do you have the stock springs?
Because buying a set of Konis and installing the stock springs on them would be a much better - and safer - idea than putting new Ground Control coilovers on a set of already blown dampers.
If you can only afford to do one thing, do that. Beggars can't be choosers.
mynameizstitch
Suspension & Brakes
Feb 17, 2009 04:24 AM
taimysho0
Aug 17, 2008 06:43 PM
don't have stock springs but i can get them fairly cheap.. im taking that route
