CRX FRONT END SWAP on civic photos
Old Nov 9, 2007 | 04:07 AM
ys1civicsi's Avatar
Default CRX FRONT END SWAP on civic photos
SO after roaming around on HT the other day I saw a veruy clean ef with a crx front end swapped onto it. It was very inspiring and I know it has been done before long ago but what I am asking for is that I cannot find this picture anywhere again after looking for it this whole week. If anyone has a picture of one of these could you please post it thanks guys.
Old Nov 9, 2007 | 05:00 AM
Harlowe's Avatar
Function>Fashion
Heres a couple pictures of my friend's hatch with CRX front.
A little beat up now
Old Nov 9, 2007 | 05:29 AM
CRXDrew's Avatar
crx front end is much nicer....
so lets add some tech to this thread:
What is needed to do the conversion?
Old Nov 9, 2007 | 05:36 AM
ludesrv's Avatar
Full front end from a CRX. Welded front fender near the bottom since the civic doesn't use plastic skirts.
HEadlights are the same, hoods are the same. Fender, bumper and some good welding is all you need IIRC.
Old Nov 9, 2007 | 05:40 AM
Harlowe's Avatar
Function>Fashion
+ CRX bumper support, and corner lights. The fenders don't HAVE to be welded. The side molding piece should keep them together.
Welding is better though.
Old Nov 9, 2007 | 06:34 AM
ludesrv's Avatar
Default Re: (Harlowe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harlowe &raquo;</TD></TR><TR><TD CLASS="quote">+ CRX bumper support, and corner lights. The fenders don't HAVE to be welded. The side molding piece should keep them together.
Welding is better though.</TD></TR></TABLE>
A good welder and some light coats of bondo should be good enough. Body work never is perfect even from factory.
Old Nov 9, 2007 | 06:55 AM
~sp33~'s Avatar
EFB055
How come its a little beat up now?
dem0nk1d's Avatar
Default Re: CRX FRONT END SWAP on civic photos (ys1civicsi)
i'd like to do this to the sedan. but remember the hatch/sedan are wider than the crx. i know for a fact the crx to hatchback conversion is a direct bolt on. i think the sedan you would need to cut fenders.
hatchboy
Sep 14, 2011 07:33 AM
91REX_RESCUE
Feb 6, 2008 04:31 AM
lipancrx
Paint and Body
Jun 5, 2007 07:00 AM
riceburners1
Feb 19, 2004 07:00 PM
