weird turbo sound
Old Nov 8, 2007 | 09:22 PM
noss88's Avatar
Default weird turbo sound
after 5-10 minutes of driving...my turbo makes a weird sound when i floor the accelerator...u know when u floor it for a long time u start hearing the turbo spool, well its not make the normal spooling sound, it sounds like something is stuck in there or something, any ideas wat it might be? btw its a d16z6 with greddy turbo kit
Old Nov 9, 2007 | 05:24 AM
turbodano's Avatar
Default Re: weird turbo sound (noss88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noss88 &raquo;</TD></TR><TR><TD CLASS="quote">after 5-10 minutes of driving...my turbo makes a weird sound when i floor the accelerator...u know when u floor it for a long time u start hearing the turbo spool, well its not make the normal spooling sound, it sounds like something is stuck in there or something, any ideas wat it might be? btw its a d16z6 with greddy turbo kit</TD></TR></TABLE>
Take the hose off the inlet of the turbo to check the shaft play there should be a little but the wheel should not rub the comp cover. Also look for scuff marks.
Old Nov 9, 2007 | 02:54 PM
JaredKaragen's Avatar
Default Re: weird turbo sound (turbodano)
here is an example of what to look for:
Old Nov 13, 2007 | 01:59 AM
noss88's Avatar
Default Re: weird turbo sound (JaredKaragen)
cool thx, imma check that out tomorrow, but what do u mean shaft play (yea not that smart with car stuff...) and is it anything serious or is it easy to fix?
Old Nov 13, 2007 | 04:46 AM
twkdCD595's Avatar
shaft play is when the shaft has out of tolerance and unwanted movement in any direction... forward, back, or side to side.
shaft movement will result in the compressor/ turbine wheels touching the housing as indicated above... which will make a very loud high pitch noise that sounds like your turbo is constantly "spooling" whenever your in boost or coming into boost.
it is semi serious... and requires usually a new turbo or a rebuild of your existing unit (which honestly it is probably not worth, it is probably cheaper to replace it if one of the wheels touched the housing).
Old Nov 18, 2007 | 11:44 PM
noss88's Avatar
Default Re: weird turbo sound (twkdCD595)
blah busy busy...anyway just checked out the turbo today, its shaft play...i checked craigslist (SF) and nobody seems to be selling a td04 greddy turbocharger...anybody have any idea where i can get another td04 greddy turbocharger or another turbo that would fit?
TURKISHFORCE
Feb 23, 2011 07:33 AM
girty
Apr 3, 2007 07:44 AM
teamvirus
Nov 5, 2006 12:33 PM
slow_redcivic
Jan 4, 2006 07:39 PM
PyroVTEC
Dec 21, 2001 11:14 AM
