b20vtec turbo?
Old Nov 8, 2007 | 08:55 PM
mistajdm's Avatar
Default b20vtec turbo?
i was wondering about goin boost but what are some pros and cons on goin b20vtec boost?
Old Nov 8, 2007 | 09:05 PM
EGhatchguy's Avatar
Default Re: b20vtec turbo? (mistajdm)
i have heard that the b20 blocks have thin cylinder walls and definitely need to be sleeved if you are putting boost to it
Old Nov 8, 2007 | 09:10 PM
93egSLEEPER's Avatar
Default Re: b20vtec turbo? (EGhatchguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGhatchguy &raquo;</TD></TR><TR><TD CLASS="quote">i have heard that the b20 blocks have thin cylinder walls and definitely need to be sleeved if you are putting boost to it</TD></TR></TABLE>
x2. but when a crvtec is boosted right the results are magnificant. sleeves cost around 1k from what ive heard.
mistajdm's Avatar
thats all i heard so far. that they have thin walls
Old Nov 8, 2007 | 09:13 PM
Default Re: (mistajdm)
if you have the time and money i say go for it...
Old Nov 8, 2007 | 09:15 PM
mistajdm's Avatar
Default Re: (93egSLEEPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER &raquo;</TD></TR><TR><TD CLASS="quote">if you have the time and money i say go for it... </TD></TR></TABLE>
im just worried about hearing stories that the motor blows easy when boosted
Old Nov 8, 2007 | 09:17 PM
if you resleeve it you shouldnt have to worry about it blowing... as long as its built correctly you should have good luck.
Old Nov 8, 2007 | 09:31 PM
mistajdm's Avatar
would i still have to sleeve the block if a was to go juice instead?
Old Nov 8, 2007 | 09:33 PM
that i honestly cant say yes or no to.... if you run a smart amount i would say no. i wouldnt put more than a 50 shot on any stock motor.
Old Nov 8, 2007 | 09:56 PM
Phenol312's Avatar
I was running a b16/b20 turbo for years on stock internals only about 7psi though good for 280whp/200tq.
Just killed a piston this summer...cylinder walls have been fine. I've been told a lot of it depends on the tune. Who can say really though.
what i can tell you is that the b20 has a siamese cast sleeve vs the b18 which has individually cast sleeves.
quick solution: find a sleeved b18a/b with 84mm bore its the same bore and stroke as a b20 and will be stronger.
And if you find a b18a/b sleeved with 84mm bore let me know im in desperate need for one.
Honestly, I cant decide whether to just sleeve my b20 or take a risk on buying a sleeved b18 block
Old Nov 8, 2007 | 10:07 PM
ViSiONxBoY's Avatar
Default Re: b20vtec turbo? (Phenol312)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mistajdm &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering about goin boost but what are some pros and cons on goin b20vtec boost?
Pros: Super mad vtak boost powa
Cons: None if you got it tuned and built it right including a resleeve
Old Nov 9, 2007 | 09:09 AM
mistajdm's Avatar
Default Re: b20vtec turbo? (ViSiONxBoY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViSiONxBoY &raquo;</TD></TR><TR><TD CLASS="quote">
Cons: None if you got it tuned and built it right including a resleeve </TD></TR></TABLE>
thanks
Old Nov 9, 2007 | 09:17 AM
Bazza's Avatar
sleeves are a must for boost cuz they have the thinnest walls and if your gonna just go nos your gonna wanna redo your pistons/valves/rods cuz youll burn em up unless you use just a 75 shot.
Old Nov 9, 2007 | 10:12 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phenol312 &raquo;</TD></TR><TR><TD CLASS="quote">I was running a b16/b20 turbo for years on stock internals only about 7psi though good for 280whp/200tq.
Honestly, I cant decide whether to just sleeve my b20 or take a risk on buying a sleeved b18 block </TD></TR></TABLE>
Yeah, stock is fine, the B20'll hold together much like any other B series engine as long as you're not trying to crank it out to 8000 RPM.
The redline of the B20Z is 6700, keep it below 6500 without putting a ridiculous amount of HP through it and it won't blow.
Yeah, the rods are what makes them weak, I'd say you can push a B20 up to about ~280hp - 300hp no prob on stock internals keeping a 6.5-6.7k redline, obviously more if you change the pistons/rods and sleeve the block.
e-g-6jdm
25
Nov 13, 2007 01:42 PM
YashiMotors
May 29, 2007 01:28 PM
3Rd GeAr PuLl
12
Feb 26, 2007 04:20 PM
lsvtechatch92
Nov 2, 2006 07:18 AM
JDMroyEG5turbo
15
Mar 3, 2006 03:01 AM
