89 Civic Si Hatch Sunroof Sun Guard Replacement
Old Nov 8, 2007 | 08:53 PM
JapJunkie's Avatar
Default 89 Civic Si Hatch Sunroof Sun Guard Replacement
I tried searching, but had no luck. My headliner is off and wanted to replace the old sun guard/ shade that pulls underneath the actual sunroof. Anyone know how that can be replaced? Does the whole sunroof assembly have to be taken out? TIA.
Old Nov 9, 2007 | 03:35 PM
JapJunkie's Avatar
Default Re: 89 Civic Si Hatch Sunroof Sun Guard Replacement (JapJunkie)
Ummm...
Old Nov 10, 2007 | 10:20 AM
JapJunkie's Avatar
TTT
Old Nov 15, 2007 | 09:44 PM
JapJunkie's Avatar
up
Old Nov 16, 2007 | 05:48 AM
EFSiR's Avatar
I'll have to scan this for you... Give me till the weekend.
Old Nov 16, 2007 | 12:40 PM
i-want-a-crx's Avatar
how did you get your headliner off my sunroof is closing but it wont go down, its shut but not all the way and sometimes it works sometimes it dont so i need to fix it
anyhelp?
Old Nov 17, 2007 | 06:04 PM
EFSiR's Avatar
I scanned it but it's too big to host on image shack...
so:
1. Slide the sunshade all the way back
2. Pry plug out of each bracket cover(each side of the glass, looking at the glass from the seat, at each side there are 2), remove the screw and slide cover off (slide it back a bit and then down) to the rear.
3. close sun roof all the way
4. remove the mounting nuts from the front and rear brackets on both sides of the glass. There are 4 per side so 8 total.
5. you now can remove the glass by lifting up and pulling forward. Watch the shims that are at each corner just above the srews. Make sure you remember where they were so that you can put it back as it was or else the glass won't be level and you'll have a leaky sunroof.
6. remove the wind deflector
7. remove the sunshade by pulling it toward the front of the car and then slightly bending it near the end to take it out.
That's it.
Old Nov 17, 2007 | 10:14 PM
JapJunkie's Avatar
Default Re: 89 Civic Si Hatch Sunroof Sun Guard Replacement (i-want-a-crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-want-a-crx &raquo;</TD></TR><TR><TD CLASS="quote">how did you get your headliner off my sunroof is closing but it wont go down, its shut but not all the way and sometimes it works sometimes it dont so i need to fix it
anyhelp?
Sorry, but might wanna search and make your own thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFSiR &raquo;</TD></TR><TR><TD CLASS="quote">I scanned it but it's too big to host on image shack...
so:
That's it.
Thanks for the reply.
Hawkrider
May 5, 2009 04:30 AM
FakeJDMEF8
Sep 26, 2004 07:39 PM
Skunk.Werks
May 11, 2004 06:33 AM
RiceRacist
Oct 3, 2003 05:40 PM
dinosa21
Feb 6, 2003 08:55 PM
