harnesses and harness bar question???
Old Nov 8, 2007 | 08:22 PM
DeDonDeRosa's Avatar
Default harnesses and harness bar question???
ok looking to get a set of harnesses and a harness bar for my dc2 but im not really sure how you go about installing the harnesses on the bar. lol i know it sound dumb but can somone explain and post a pic of how and where u exactly bolt them in. thanks
Old Nov 9, 2007 | 03:58 AM
Default Re: harnesses and harness bar question??? (DeDonDeRosa)
anyone
Old Nov 9, 2007 | 04:44 AM
coolhandluke's Avatar
No need to bump, this is a very well run forum so be patient.
Running harnesses without rollover protection is a big safety issue. However, it is better to run just a harness bar vs. nothing and run the risk of spinal compression. This is a question that would better be addressed in the Road Race Forum just fyi.
I personally have an AutoPower 4pt rollbar and attach the harnesses to the rollbar. Let me search for pictures and instructions.
Links:
https://honda-tech.com/zerothread?id=591951
http://www.soloracer.com/rsxrallye4.html *Scroll down for Install tips*
https://honda-tech.com/zerothread?id=226909
http://www.sandmracing.com/ssabelt.html
https://honda-tech.com/zerothread?id=517099
Modified by coolhandluke at 8:05 AM 11/9/2007
Modified by coolhandluke at 8:06 AM 11/9/2007
Modified by coolhandluke at 8:07 AM 11/9/2007
Old Nov 9, 2007 | 11:16 AM
Relic1's Avatar
harness bar;
I run this one.... https://honda-tech.com/zerothread?id=1592059 (scroll down a little)
I had a more difficult time figuring out how to loop the harness around the bar than installing the bar.
if you'd like pictures of an install... sparco's instructions... http://www.sparcousa.com/resourceFiles/47.pdf
not exactly the same as the bar I have, but it's very close.
harness;
it all depends on which one you buy.
I have the Schroth Profi II ASM FE. The instructions that came with it are detailed to the point of confusing when you first read them. But when you step though it yourself it all makes sense.
instructions and details at http://www.schrothracing.com
Old Nov 9, 2007 | 11:37 AM
migs's Avatar
Default Re: (Relic1)
I made this post a few years ago. Hopefully it helps you.
https://honda-tech.com/zerothread?id=1452398
Old Nov 9, 2007 | 12:56 PM
Default Re: (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">I made this post a few years ago. Hopefully it helps you.
https://honda-tech.com/zerothread?id=1452398</TD></TR></TABLE>
Great info Migs.
Old Nov 9, 2007 | 06:16 PM
JjuuN R's Avatar
Default Re: (coolhandluke)
What are some good places to buy the Sparco Harness Bar?
Old Nov 10, 2007 | 06:20 AM
Default Re: (JjuuN R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">What are some good places to buy the Sparco Harness Bar?</TD></TR></TABLE>
Evasive is the only place I'v found. For $400 though, you can get a an Autopower for that amount.
http://www.evasivemotorsports....-BARS
Old Nov 10, 2007 | 06:22 AM
JjuuN R's Avatar
Well I already have a custom weld in 6pt, it's either finish it and turn it into a full cage, or get a harness bar...
Old Nov 10, 2007 | 06:40 AM
I thought you did. I wasn't sure if you wanted it for a friend, another car, etc. I'm not sure how I would like/handle a 6pt for driving on the street. Its really your car. Is this 6pt the setup you have always had?
DailyDriven259
May 31, 2015 07:05 PM
MIEj1
32
Jun 17, 2012 10:17 AM
Powered by Honda
15
Mar 5, 2004 06:54 AM
function83
Mar 3, 2003 07:07 PM
JSR3STS
24
Jan 31, 2003 09:24 AM
