Help on installing pads for my brakes.
Old Nov 8, 2007 | 03:46 PM
Vistage's Avatar
Default Help on installing pads for my brakes.
I did a search on the whole forum nothing about installing pads. As I have lost my haynes manual i am in need of a link or a guide. I got caught on the top caliper bolt. There is a cover. I dont want to pry it off with out getting a second opinion from a person or from a install guide. Would anyone be able to help me?
Old Nov 8, 2007 | 03:58 PM
BlueIntegraBoy's Avatar
Default Re: Help on installing pads for my brakes. (Vistage)
Is this for the rear brakes? I don't remember a cover for the front.
Old Nov 8, 2007 | 04:16 PM
1992Si's Avatar
Remove the cover, any way you can, you don't need it.
The other hard part is pulling the stupid screws that hold the rotor on the hub. Drill them out and leave them out.
Start with a small drill and work your way up to a 3/8 drill. You don't have to get all the head off, you can pull the rotor over the last small piece if you were not centered good.
Put anti-seize on the bolts when you put them back in. I also put a little anti-seize on the lug nuts threads.
Old Nov 8, 2007 | 04:18 PM
hoo my gosh's Avatar
Default Re: (1992Si)
what cover? got a pic?
Old Nov 8, 2007 | 04:25 PM
1992Si's Avatar
Default Re: (hoo my gosh)
I'm thinking its the rock shield on the rear brakes.
Old Nov 10, 2007 | 09:01 PM
so you're telling him to take it off cause he doesn't need it but you dont even know what it is?
Old Nov 10, 2007 | 10:46 PM
ron212002's Avatar
Extra parts hmmm thats not good .
Old Nov 11, 2007 | 12:17 AM
n1_egsex's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">Remove the cover, any way you can, you don't need it.
or you can just do it correctly and use an impact driver
GoLowDrew
Sep 22, 2008 07:21 AM
schumi
Feb 11, 2008 07:51 AM
imadigitalgod
Sep 8, 2006 02:51 PM
94TealCivic
27
Feb 3, 2004 04:03 PM
95GSRRacer
Jun 29, 2002 05:28 PM
