Trouble Codes Part 3
Ok, went to the junkyard and grabbed a MAP sensor, PA sensor, and ECU. Map sensor didn't fix the prob, PA sensor didn't fix the problem, the ECU however did. But I just grabbed one out of an AUTO model cause I couldn't find a Manual. Now the check engine light comes on but it's for a code 19, the A/T lockup Solenoid which a manual doesn't have. Any way to clear that code so it doesn't register?
krz6jdm
Feb 21, 2006 01:36 AM
