00 Civic Si: CEL! (o2 sensor low voltage)
Old Nov 8, 2007 | 11:48 AM
wade's Avatar
Default 00 Civic Si: CEL! (o2 sensor low voltage)
I was driving down the road, car hit a huge uprising from road construction workin on a bridge. CEL immediately came on. Primary o2 low voltage code.
I have heard, even if i fix the problem, the engine light will come back as obd2 cars STORE it unless removed by a code scanner. Even if i disconnect the negative battery terminal the light will come back eventually. True?
Old Oct 11, 2008 | 07:45 AM
crazy-ej8's Avatar
Default Re: 00 Civic Si: CEL! (wade)
i am having the same problem as this. has anyone come across it and how was it fixed?
Old Oct 11, 2008 | 08:40 AM
blakkvtec's Avatar
Default Re: 00 Civic Si: CEL! (crazy-ej8)
If you disconnect the negitive cable from the battery and leave it off for a min. the ecu will reset itself and the code will be gone. Not saying the code won't come back, because if you haven't fixed the problem it will come back.
civicboy1128
13
Nov 7, 2013 11:50 AM
Elson23
Nov 21, 2009 08:40 AM
fryguy190
Mar 16, 2008 10:21 PM
hack_tc
Nov 28, 2007 11:39 PM
Qwikrex
Jun 22, 2002 12:52 PM
