throttle body question
Old Nov 8, 2007 | 09:42 AM
ge_itr's Avatar
Default throttle body question
will aftermarket b-series tb's fit the h22 euro r.... or what tb's are compatible with the h22 euro manifold? thanks.
Old Nov 8, 2007 | 09:59 AM
Hawkze_2.3's Avatar
Default Re: throttle body question (ge_itr)
Yeah, should be the same bolt pattern. I have an ITR TB on my H23.
Old Nov 8, 2007 | 10:08 AM
flyrod's Avatar
most stock TB's will leak on the euro R. Check out the euro R threads on this.
Old Nov 8, 2007 | 10:26 AM
ge_itr's Avatar
Default Re: throttle body question (flyrod)
what about aftermarket's?
Old Nov 8, 2007 | 11:21 AM
ge_itr's Avatar
planning to get my bdl throttle body from HT user hybrid-performance.com. let me know if this is legitable.
https://honda-tech.com/zerothread?id=1895660
Old Nov 8, 2007 | 03:18 PM
Rosko's Avatar
ITR and S2K tb's work great as well as the 99-00 B16 (60mm) tb's all other b-series (the ones I've tried) have a different bolt pattern and won't fit.
Aftermarket H22 billet tb's should all work great too.
also if you use the ITR or S2K tb be sure to use the corresponding gasket rather then the H22 one. gaskets are identical part #'s for the ITR and S2K btw.
Old Nov 8, 2007 | 04:39 PM
Sam_J's Avatar
Default Re: throttle body question (Rosko)
I know the stock h22 TB will leak, I've already lined up my stock tb to my euro r mani, question is, think I could just use gasket maker and plug it up??
Old Nov 8, 2007 | 04:48 PM
boostedh22lude1's Avatar
Default Re: throttle body question (Sam_J)
yes they fit, they have the same bolt pattern, but make sure u leave the map on it and dont use it,
Old Nov 8, 2007 | 07:40 PM
ge_itr's Avatar
so will the bdl throttle bodies from hybrid-performance.com work for the euro r manifold???
Old Nov 8, 2007 | 08:06 PM
Rosko's Avatar
Default Re: (ge_itr)
just order one for an H22 and you'll be fine.
Old Nov 9, 2007 | 08:56 AM
ge_itr's Avatar
it's weird how the bdl for a h22 will fit the euro r but not the stock h22 tb.
hybrid-performance says that all bdl are the same, b or h series.
Old Nov 9, 2007 | 11:12 AM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ge_itr &raquo;</TD></TR><TR><TD CLASS="quote">it's weird how the bdl for a h22 will fit the euro r but not the stock h22 tb.
hybrid-performance says that all bdl are the same, b or h series.</TD></TR></TABLE>
Old Nov 9, 2007 | 11:14 AM
Rosko's Avatar
Thats just because billet tb's don't use a fitv like the stock h22 tb. The stock tb works fine as long as you seal it up correctly.
I think that BDL slots some of the holes to make them work for both, but not everyone does that. I have several b-series tb's here that are deffinately different.
hamadiscool
Jan 15, 2007 08:37 AM
zumiez007
Jul 29, 2005 06:11 PM
B SERIES US
Oct 9, 2004 02:50 PM
Jdmbsixteen
Oct 16, 2003 11:05 AM
ludespeeder
Jun 23, 2002 06:39 PM
