Gas brand preference, and does it matter?
Old Nov 8, 2007 | 06:11 AM
HtxPrelude2K's Avatar
Default Gas brand preference, and does it matter?
What brand of gas do you use? Octane rating?
Also, does it matter to you at all, or do you settle for the cheapest gas? Please explain... would love to hear people's opinion and experiences.
I use Shell V-Power (Octane 93 as required) all the time on the Prelude, 335i, and A4. For the SUV, I just use the Krogers/Randall's gas (Octane 89 as required)
Old Nov 8, 2007 | 06:26 AM
xod's Avatar
xod
Default Re: Gas brand preference, and does it matter? (HtxPrelude2K)
I've been pumping chevron for 3years 91 octane. I tried Arco gas when i first got my car. Didn't notice the difference but less gas mileage. This was on a h23 92 lude. btw the arco gas did have ethanol in it.
I now drive a 99 sh. For some reason i feel like i get less miles.
This might not be related but i tried 89 octane at arco and my car stalled on idle.. for the 92lude
Old Nov 8, 2007 | 06:42 AM
FloGgY's Avatar
i use shell 93 v power, think about it, if race cars and F1 cars use it to get the best performance then i am too.
sheetz and exxon mobil are cheap but i've blown up a motor on they'r pump gas and cant trust it, it ruined my valves.
Old Nov 8, 2007 | 07:38 AM
NirVTEC's Avatar
Default Re: Gas brand preference, and does it matter? (FloGgY)
Friends did a test on a Motorcycle and Citgo 93oct beat Shell, Mobil, BP as far as power. It was a 3rwhp difference on a ~180whp GSX-R1000. Conditions set by Pros in a controlled environment.
I use Citgo whenever I can...
Personally I have always wanted to do some gas testing on Preludes. Considering they run on 100oct in Japan, I bet the 93oct in my JDM H22A is costing me some power/economy. Maybe we'll see one day.
Old Nov 8, 2007 | 08:00 AM
underbelly's Avatar
Octane is rated diffrent in japan. 98 RON is 94 (R+M)/2 here in the states.
So if you were to get 100 RON fuel in japan, it is equivalent to 96 (R+M)/2
Old Nov 8, 2007 | 08:06 AM
choptopprelude's Avatar
Default Re: Gas brand preference, and does it matter? (xod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xod &raquo;</TD></TR><TR><TD CLASS="quote">I've been pumping chevron for 3years 91 octane. I tried Arco gas when i first got my car. Didn't notice the difference but less gas mileage. This was on a h23 92 lude. btw the arco gas did have ethanol in it.
You definately don't want to do this. Preludes require 92 or 93, not 91. Especially not 89.
Old Nov 8, 2007 | 08:24 AM
NirVTEC's Avatar
Default Re: Gas brand preference, and does it matter? (choptopprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by choptopprelude &raquo;</TD></TR><TR><TD CLASS="quote">
You definately don't want to do this. Preludes require 92 or 93, not 91. Especially not 89.</TD></TR></TABLE>
Some states don't have 92/93. In Cali, 91 is premium. In PA you can get 94 at the pump.
I was told that in Japan, gas stations sell 95-97-100.....
Old Nov 8, 2007 | 08:39 AM
sean1121's Avatar
Default Re: Gas brand preference, and does it matter? (::NirVTEC::)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by choptopprelude &raquo;</TD></TR><TR><TD CLASS="quote">You definately don't want to do this. Preludes require 92 or 93, not 91. Especially not 89.</TD></TR></TABLE>
91 is premium and 93 is super premium in texas. My H22a doesn't seem to care either way.
carnot's Avatar
I am under the impression that if you are running a stock motor with feedback control from the knock sensor that you can pretty much use any octane rated gas. The controller in the ECU will retard the timing if the knock sensor indicates there is detonation occurring. When the ignition timing is retarded the motor will make less power and run less efficiently. Therefore, running premium gas should produce the maximum hp and fuel economy from the engine and this is why Honda recommends the type of fuel it does. Running a lower grade fuel shouldn't hurt the motor it just won't be making as much power or getting as many mpg.
Old Nov 8, 2007 | 08:47 AM
underbelly's Avatar
the motor first has to knock(ping) before it retards the timing. And when it does retard the timing, it doesnt stay retarded till u put the right gas in
Old Nov 8, 2007 | 10:25 AM
alpinefr3ak's Avatar
the 4th and 5th gen preludes do not "require" 92+ octane. They only need 91 octane to run at peak performance with your basic bolt ons. The only time you would need higher octane is if you have FI or have significantly changed the engine. Theres a HUGE thread about this, you should SEARCH before asking these kinds of questions
as for brand of gas, I prefer Chevron or Texaco (they both use the same now). The reason is that I've never gotten a bad tank of gas from them, I have gotten some bad gas from a few other brands.
Old Nov 8, 2007 | 02:14 PM
Apex1972's Avatar
Default Re: Gas brand preference, and does it matter? (alpinefr3ak)
I usually use Shell 93, but I will sometimes use Amoco 93. My car seems to like both.
Old Nov 8, 2007 | 02:17 PM
vinuneuro's Avatar
Default Re: Gas brand preference, and does it matter? (Apex1972)
Shell V-Power nothing else.
Old Nov 8, 2007 | 06:55 PM
shhh151's Avatar
Default Re: Gas brand preference, and does it matter? (vinuneuro)
as well shell v-power, all the other gas gives me less gas mileage and performance!
Old Nov 8, 2007 | 07:37 PM
ethereal2pt2's Avatar
Default Re: Gas brand preference, and does it matter? (shhh151)
i've been pumping 92oct @ chevron w/ the assumption that they were better. i've never put shell's gas in my car. anyone want to enlighten me as to why they're better? except for the extra octane rating of course.
Old Nov 8, 2007 | 07:51 PM
MilanoLude's Avatar
91 octane is the highest we get, it's what I use. But I usually get it from wherever is cheapest / most convienent.
Old Nov 8, 2007 | 09:05 PM
Mike1995HondaPrelude's Avatar
Default Re: Gas brand preference, and does it matter? (MilanoLude)
This all sounds really ridiculous to me. So people here is getting a very noticeable difference in power using Shell V-Power. I think its the "V-Power" name and price thats making you think you're getting major gains. I just go up to Smiths gas station and 91. I save like 15 cents a gallon cuz i shop at smiths. ****, if the quality of gas is that important stop by at ur local airport and get 100LL.
Old Nov 9, 2007 | 06:11 AM
Default Re: Gas brand preference, and does it matter? (ethereal2pt2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ethereal2pt2 &raquo;</TD></TR><TR><TD CLASS="quote">i've been pumping 92oct @ chevron w/ the assumption that they were better. i've never put shell's gas in my car. anyone want to enlighten me as to why they're better? except for the extra octane rating of course.</TD></TR></TABLE>
The best I had with Chevron was 290 miles on a full tank. The one try disappointed me, and I never have gone back. The 'Techron' stuff is BS. Stick to what most of us use... Shell V-Power. Hopefully you'll see numbers like most of us... over 325miles full tank.
Old Nov 9, 2007 | 06:34 AM
Giant_Bean's Avatar
check this out: http://www.toptiergas.com/
namewasdallas
21
Jun 4, 2012 08:48 AM
pootie.teng
Jul 18, 2007 05:43 AM
ck123
77
Jul 7, 2006 07:23 PM
professorman
Mar 5, 2003 03:39 PM
DIRep972
Oct 11, 2001 05:02 AM
