hood wont close after swap
Old Nov 8, 2007 | 05:45 AM
boosted28's Avatar
Default hood wont close after swap
i put a b16a2 in my 90 civic hatch and now the hood is hittin the valvecover.
im using hasport mounts,but other than that idk.
any ideas?
im sure one of u can make me look stupid.lol
Old Nov 8, 2007 | 06:27 AM
ludesrv's Avatar
Cut the webbing from under the hood where it's touching. Cheapest/easiest solution. That's odd tho. HASport usually makes there kits to fit under the hood. Your car ever been in a front end accident?
PS: Congrats on the swap.
Old Nov 8, 2007 | 10:00 AM
89hatcher's Avatar
prop the hood...thats the cheapest solution.
Old Nov 8, 2007 | 11:14 AM
gibsanez's Avatar
Default Re: (89hatcher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hatcher &raquo;</TD></TR><TR><TD CLASS="quote">prop the hood...thats the cheapest solution. </TD></TR></TABLE>
Buying washers and bolts is cheaper than turning on a mini-grinder?
Old Nov 8, 2007 | 11:16 AM
Boricua8503's Avatar
Default Re: hood wont close after swap (boosted28)
you could get a SIR style hood. or cut Exo-skeleton of the hood. Take some clay and put it on top of valve cover then close hood and see where clay sticks. Thats where you cut.
Old Dec 17, 2007 | 06:32 PM
boosted28's Avatar
thanks guys ill try to cut and use washers.
Old Dec 17, 2007 | 06:40 PM
gursh d's Avatar
cut the webbing where it's hitting your valve cover, or use spacers, or get a siR style hood. Most people cut out webbing and keep stock hood.
Old Dec 17, 2007 | 06:54 PM
CW-ITR's Avatar
Default Re: hood wont close after swap (gursh d)
If you autox or road race like some of us, use the washers. This also help cool down the engine bay
AK_CRX
87
Apr 25, 2012 10:34 AM
Momentum
Appearance Build Threads
May 15, 2008 05:26 PM
type B16
11
Nov 20, 2006 11:56 AM
mo0cow
Aug 31, 2005 02:15 PM
Black R
Jan 29, 2004 03:50 AM
