b16 starter (searched)
Old Nov 8, 2007 | 04:05 AM
wrestler72's Avatar
Default b16 starter (searched)
I know this has been covered many times before and i searched and 3 pages came up but for a JDM B16 motor everyone says a 90-93 integra starter works. I just got a 93 gsr starter and it bolts up but it does nothing. After looking at both starters the gear that engages the flywheel is completly different. Everyone says a 200 si starter wont work but why is that. They both look identical??
Old Nov 8, 2007 | 09:04 AM
wrestler72's Avatar
Default Re: b16 starter (wrestler72)
Well i did the research at the parts store and found one that matches up perfect. Looks wise a 94-95 B16 Del Sol matches up perfect. Now all i gotta do is wait to get it in and try it out.
Old Nov 8, 2007 | 11:59 AM
alscrx's Avatar
By the way the integra one works, But its for an integra LS.
Gsr is different!
Old Nov 8, 2007 | 12:58 PM
wrestler72's Avatar
The 93 LS and the 93 GSR are the same part number along with the 92 LS/GSR. The 90 and 91 LS's have diff. parts numbers than the others.
By the way i got this information off acuraoemparts.com
Modified by wrestler72 at 2:14 PM 11/8/2007
Old Nov 8, 2007 | 01:20 PM
alscrx's Avatar
Default Re: (wrestler72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrestler72 &raquo;</TD></TR><TR><TD CLASS="quote">The 93 LS and the 93 GSR are the same part number along with the 92 LS/GSR. The 90 and 91 LS's have diff. parts numbers than the others.
Modified by wrestler72 at 2:14 PM 11/8/2007</TD></TR></TABLE>\
To be more clear...90-91 integra ls starter. Sorry for mis information
Old Nov 9, 2007 | 01:48 PM
wrestler72's Avatar
well for those who are interested a 94-95 B16 Del Sol starter works great
Old Nov 16, 2007 | 08:03 AM
612tunerh22's Avatar
I have a 99 Si aftermarket starter on my B16 obd0 engine and it works just fine
Old Mar 5, 2012 | 09:00 AM
CRXB16A702's Avatar
Default Re: b16 starter (searched)
i have a 91 crx with a b16a that the starter would not ingage on upon inspection i discovered that the bolt wholes on the starter did not match up with the ones on my block and only the top whole had a bolt holding it on, anyways i was wondering if i could get some help determining whitch gen. b16 i have exactly and witch starter do i need???
variable
Feb 17, 2009 01:49 PM
Cory man
Jun 9, 2007 10:21 AM
naptownrex
Jul 1, 2006 09:57 AM
b00stedbyFastrax
Jul 28, 2002 03:57 PM
b00stedbyFastrax
Jul 28, 2002 01:47 PM
