B18C oil leak
Old Nov 7, 2007 | 08:08 PM
ttomred4000's Avatar
Default B18C oil leak
hey guys. new to forum. my 1994 dc2 has an oil leak. im not sure what the source is, could be a seal or something more serious. please help haha!
http://i111.photobucket.com/al...k.jpg
Old Nov 7, 2007 | 08:35 PM
nate_2k5's Avatar
Default Re: B18C oil leak (ttomred4000)
the thing you have circled is the headgasket, is it only leaking there? it might be coming from the more likely source of the cam seal, which is right behind the vtec solenoid
Old Nov 8, 2007 | 04:54 AM
dyingwish's Avatar
Default Re: B18C oil leak (nate_2k5)
^^^yep the cam seal (cam plug). IT drools down the head and collects there on the edge of the headgasket. You should also have a bit on where the tranny case meets the block.
Old Nov 8, 2007 | 07:36 AM
jomama's Avatar
dude, that's nothing... compared to my daily driver. man, i should consider fixing mine. just keep adding more oil when it goes low
Old Nov 8, 2007 | 08:54 AM
VTEC_PRODUCTION's Avatar
Default Re: (jomama)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama &raquo;</TD></TR><TR><TD CLASS="quote">dude, that's nothing... compared to my daily driver. man, i should consider fixing mine. just keep adding more oil when it goes low </TD></TR></TABLE>
lol yea thats what im talking about!
anyway are you sure its not coming down the side of the head? wipe **** up and watch it closely. you should be able to gauge the problem a little better.
Old Nov 8, 2007 | 09:20 AM
deftonerider's Avatar
it is also very likely coming from the distributor o ring they will leak oil and it will travel across the head to their
Old Nov 9, 2007 | 02:22 PM
dwamp2006's Avatar
its gotta be coming from the head gasket, theres no other signs in the pic of it leaking from anywhere else. let me know....
Old Nov 9, 2007 | 02:37 PM
climb_on's Avatar
Default Re: (dwamp2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwamp2006 &raquo;</TD></TR><TR><TD CLASS="quote">its gotta be coming from the head gasket, theres no other signs in the pic of it leaking from anywhere else. let me know....</TD></TR></TABLE>
its probably not the head gasket otherwise he would have far more problems than just a minor leak (smoking, oil in coolant)
i have a pretty similar leak on my motor trying to figure what it is, but it just makes me mad cause makes the motor look dirty i really dont lose any oil tought.
i would clean it up and try to pin point the problem, thats what im doing!
Old Nov 9, 2007 | 03:24 PM
95dc2teg's Avatar
Default Re: (climb_on)
it could be any one of the three: cam plug, vtec solinoid gasket, or distributor o-ring. I had a problem like that and changed my vtec solinoid gasket and distributor o-ring and it fixed the problem. Just look at it closly to figure it out.
boomersz
Apr 4, 2007 12:14 PM
vlc92189
10
Jan 19, 2007 09:05 AM
JDMisGOOD
12
Nov 12, 2005 09:54 PM
brixity
Apr 10, 2005 08:17 PM
DriveSlowHomie
Sep 22, 2004 03:50 AM
