What Bolts/Studs to use when you remove butterfly plate?
Old Nov 7, 2007 | 07:48 PM
EG8's Avatar
EG8
Default What Bolts/Studs to use when you remove butterfly plate?
I was wondering what bolt or stud do you use when you remove the IAB plate for the butterflies, since its shorter?
Old Nov 8, 2007 | 12:01 AM
Hawkze_2.3's Avatar
Default Re: What Bolts/Studs to use when you remove butterfly plate? (EG8)
Measure the thickness of the plate, then buy bolts/studs that are that much shorter than the stock bolts/studs, then install them.
Old Nov 16, 2007 | 09:46 AM
flatblack-h22's Avatar
any numbers if you was to remove the butterfly plate>
Old Nov 16, 2007 | 10:19 AM
Hawkze_2.3's Avatar
Default Re: What Bolts/Studs to use when you remove butterfly plate? (Mr.EGG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EGG &raquo;</TD></TR><TR><TD CLASS="quote">any numbers if you was to remove the butterfly plate&gt;</TD></TR></TABLE>
15, 72, 23, 8, and 187.
Old Nov 16, 2007 | 11:04 AM
mgags7's Avatar
Default Re: What Bolts/Studs to use when you remove butterfly plate? (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
15, 72, 23, 8, and 187.</TD></TR></TABLE>
Dude, 187 is WAYYYY off....
Old Nov 16, 2007 | 01:13 PM
AmauryR's Avatar
Default Re: What Bolts/Studs to use when you remove butterfly plate? (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
Dude, 187 is WAYYYY off.... </TD></TR></TABLE>
lol, oh and to the op: when you bolt everythign up, check for clearance w/ the fuel feed line to the throttle body pulley (its really REALLY close, but doable). As far as post install, feels like it did before w/ the plates. No really noticable diff, if that helps any. later.
Old Nov 19, 2007 | 08:12 AM
MoonScryer's Avatar
If you want OEM studs, don't know why, you can use the throttle body studs off an F series manifold. Three of them will fit, one is short. I had a couple intake manifolds laying around, and just tried it.
Also, watch the coolant hoses on the IACV; one will touch the intake manifold.
D16SohcVtec
Feb 16, 2008 02:00 PM
crxluv2
Dec 19, 2005 03:01 PM
_Cyclone_
10
May 16, 2005 01:15 PM
STS_Underdog
Jul 27, 2004 12:05 PM
h22a193
Jun 20, 2004 05:02 PM
