Calipers
Hi i was woundering which calipers are the same as the 91 crx si i need replacement for mine i just replaced the disk with power slots and pads but the calipers brake hold all the time like they dont go back in dont know why they should so now i need the calipers i have the 91 crx spindles and was woundering if the 89 si civic or 88 crx calipers would be the same and which ones are better. Thank
here's an idea... GET THEM FOR A '91 CRX!
and i hope your not thinking of replacing just one. if it's a front one, replace both fronts, a back, replace both backs.
EDIT: how much more power did your "power slots" add?
Modified by loudandlow at 12:06 AM 11/8/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudandlow »</TD></TR><TR><TD CLASS="quote">EDIT: how much more power did your "power slots" add?</TD></TR></TABLE>
cold man...that's just cold...
Since no one has bothered to answer the question...
If you're referring to the front calipers then you will have to get new calipers specifically for the 90-91 CR-X Si. The 88-89 ones won't work and none of the front calipers from the 88-91 Civic's (Si or otherwise are compatible).
If you're referring to the rear calipers then you have a few more options: 90-01 Acura Integra, Del Sol VTEC, EG Civic EX w/ABS and 99-00 Civic Si rear calipers are all cross compatible.
Hope that helps...
Hope that helps...
Hey why would i be refering to the back ones since the rest of the civic dont have disk calipers in the back DUH and them power slot added a **** load of power
You never specified whether you had a CRX Si or a Civic Si. All you asked about was what calipers were compatible with the 91 CRX Si (which my last post answered). You never specified front or rear (which the 91 CRX Si has both of). Since you're apparently incapable of providing complete or coherent information I covered all the bases.
Bunch of ungrateful under-educated sob's around here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad »</TD></TR><TR><TD CLASS="quote">Hey why would i be refering to the back ones since the rest of the civic dont have disk calipers in the back DUH </TD></TR></TABLE>
if your just gonna be a dick to people that try to help you, GTFO of here
no i got it figured out i bought new disk and pad for the front and one of the caliper were bad so i was wondering if one of the other ef would be similar but i just got two new 91 si calipers so it should be good it is a turbo civic so i should of got bigger calipers but for now it should be good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudandlow »</TD></TR><TR><TD CLASS="quote">if your just gonna be a dick to people that try to help you, GTFO of here
And the best part is he sends me an IM telling me I'm the moron!
</TD></TR></TABLE>And the best part is he sends me an IM telling me I'm the moron!
Jonathan_ED3
22
Aug 25, 2005 03:26 PM
redzcstandardhatch
Jul 28, 2003 04:32 AM
