Suspension & Brakes Theory, alignment, spring rates....
EG rear swaybar... subframe bracing needed???
Old Nov 7, 2007 | 04:26 PM
pgpunkguy's Avatar
Default EG rear swaybar... subframe bracing needed???
i got a integra gsr rear swaybar (and control arms).
can my CX rear subframe hold the pressure of the gsr swaybar?
or do i need a subframe bracing.
i think i read that EKs needed the bracing, but EGs don't. is this true???
Old Nov 7, 2007 | 05:05 PM
BlueIntegraBoy's Avatar
Default Re: EG rear swaybar... subframe bracing needed??? (pgpunkguy)
You most likely don't need any bracing.
Old Nov 7, 2007 | 05:44 PM
pgpunkguy's Avatar
Default Re: EG rear swaybar... subframe bracing needed??? (BlueIntegraBoy)
you don't sound so certain...
Old Nov 7, 2007 | 05:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpunkguy &raquo;</TD></TR><TR><TD CLASS="quote">you don't sound so certain...</TD></TR></TABLE>
Well, the Integra and Civic share the same subframe with each other, only the ITR is reinforced.
Old Nov 7, 2007 | 06:22 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpunkguy &raquo;</TD></TR><TR><TD CLASS="quote">i got a integra gsr rear swaybar (and control arms).
can my CX rear subframe hold the pressure of the gsr swaybar?</TD></TR></TABLE>
Yes.
Old Nov 7, 2007 | 09:32 PM
.:Made in OC:.'s Avatar
when you go 22mm a brace or a reinforcement kit is recommended.
Old Nov 8, 2007 | 03:40 AM
pgpunkguy's Avatar
Default Re: EG rear swaybar... subframe bracing needed??? (.:Made in OC:.)
cool... thanks all
Old Nov 8, 2007 | 08:08 AM
b18LS's Avatar
Yes, you will be fine with justa GSR bar, without reinforcement. Actually I have a bar if you want it for free.
Old Nov 8, 2007 | 09:16 AM
pgpunkguy's Avatar
Default Re: EG rear swaybar... subframe bracing needed??? (b18LS)
i'll take the end links and bushings/brackets (have the bar and LCAs already)
1QwIkEf
Aug 18, 2007 08:26 PM
93civicsedan
Mar 18, 2005 06:44 AM
celph.
Dec 19, 2003 06:46 AM
typeee
May 6, 2003 10:48 AM
KRiS1
12
Oct 20, 2002 08:28 PM
