After market exhaust
Old Nov 7, 2007 | 03:33 PM
Shaynepolevault's Avatar
Default After market exhaust
I got a exhaust system and was wondering about the catalytic converter! the two screws with the springs on it, the ones that connect the catalytic converter to the header, hod you take them off I dont want to break anything? thanks
Old Nov 7, 2007 | 03:36 PM
nix94delsol's Avatar
Default Re: After market exhaust (Shaynepolevault)
y take them off?
thats not that much of a weight reduction
Old Nov 7, 2007 | 03:37 PM
93egSLEEPER's Avatar
all you do is unbolt them like any other bolt and they will pop loose. when you put them back in you will need something to compress the spring so you can put the nut on the bolt.
Default Re: After market exhaust (nix94delsol)
im goint to take them off to put the exhaust on, its easier for me taking it off and then connecting it to the new exhaust and putting it back on
Old Nov 7, 2007 | 03:39 PM
Default Re: After market exhaust (93egSLEEPER)
what will i need to compress the spring! and is it hard to do!
Old Nov 7, 2007 | 03:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaynepolevault &raquo;</TD></TR><TR><TD CLASS="quote">what will i need to compress the spring! and is it hard to do! </TD></TR></TABLE>
vice grips?
Old Nov 7, 2007 | 03:43 PM
I used the C clamp style vice grips on the edges and work nicely
Old Nov 7, 2007 | 03:44 PM
but how do you get the bolt through the spring if the vise grips are compressing it?
Old Nov 7, 2007 | 03:45 PM
hit the bolts 1st
Old Nov 7, 2007 | 03:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaynepolevault &raquo;</TD></TR><TR><TD CLASS="quote">but how do you get the bolt through the spring if the vise grips are compressing it?</TD></TR></TABLE>
LOL.... ok
u put the bolt in the spring, put the vice grip on the edge of the spring and the edge of the bolt and squeeze it to gether... just make sure the bolt can pass by the vice grips when compressed, but the bolt through the holes, and put the nut on.
Floored
Jul 17, 2006 07:37 AM
escape2me
Nov 23, 2005 08:06 AM
egzo04
Sep 30, 2005 06:44 PM
hype r 555
Aug 31, 2004 01:30 PM
10seconds
28
Feb 14, 2003 10:19 PM
