Door Locks on CRX
Old Nov 7, 2007 | 03:28 PM
bobash69x2's Avatar
Default Door Locks on CRX
Does second gen CRX have a seperate key for the door lock and the ignition? I just got an 88 DX and the ignition key wont unlock the door... input?
Old Nov 7, 2007 | 03:35 PM
black0hatch's Avatar
Default Re: Door Locks on CRX (bobash69x2)
no the crx you bought was probably stolen at one time or another and the ignition was changed but not the door locks.
Old Nov 7, 2007 | 04:18 PM
STREETWERKZ's Avatar
Default Re: Door Locks on CRX (black0hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black0hatch &raquo;</TD></TR><TR><TD CLASS="quote">no the crx you bought was probably stolen at one time or another and the ignition was changed but not the door locks.</TD></TR></TABLE>
i wouldnt assume it was stolen. sometimes the crx ignition switch goes out on its own, and the owner replaces it with another OEM unit. honda sometimes matches all the keys and locks to one another for an additional charge. that person probably chose not to.
Old Nov 7, 2007 | 06:02 PM
bobash69x2's Avatar
Yeah im going to call the service dpt at a honda dealership and see if they have the specs on file, since its an 88 im sceptical.. Hopefully a locksmith wont charge an arm and a leg if Honda cant do anything for me
Old Nov 8, 2007 | 10:28 AM
Default Re: (bobash69x2)
i wouldnt assume it was stolen. sometimes the crx ignition switch goes out on its own, and the owner replaces it with another OEM unit. honda sometimes matches all the keys and locks to one another for an additional charge. that person probably chose not to. </TD></TR></TABLE>
but when a ignition switch goes bad you dont replace the whole lock just the switch on the back. the whole lock is expensive and is usually only replaced when its broken off. and the dealership wont be able to do anything cause the car is so old. go to a locksmith.
Old Nov 8, 2007 | 10:48 AM
Tyson's Avatar
you can rekey the door. its pretty easy actually. i dont think you can rekey the igniton.
Modified by Tyson at 12:17 PM 11/8/2007
Old Nov 9, 2007 | 06:35 AM
philkehn's Avatar
anyone wanna point me in the direction of how to rekey or should i just go to a locksmith.... i have the same problem just my driver door is off another car
Old Nov 9, 2007 | 06:38 AM
bobash69x2's Avatar
Default Re: (philkehn)
I got lucky enough where a friend of mine got the key code for my car, but the advice i got to get the key code without your VIN (since its a diff door) is to pull the lock out and get the code off the lock, but i dont know specifics.
EeeJayEight
Nov 17, 2006 10:10 PM
hondahak
May 12, 2006 05:06 PM
p3t3rxp4n
May 8, 2006 01:48 PM
