Blower motor problem!!! No HEAT!!
OK I have a 93 Integra Ls, The blower motor doesnt work at all. I replaced the motor and resistor with one that I know works. No luck. I removed them both again and checked the wired for power, none on any wire. So i pulled out the switch, no power there either except for the smaller plug had power. Help me out!!!! there also doesnt seem to be a fuse for it? so I pulled out all of the fuses and checked everyone, not for power just to see if they were blown.
I searched! but nothing covered this.
Thanks in advance
Matt
Thanks in advance
Matt
are you sure that ur two way water valve is opening and closing properly where it goes in to the back of the fire wall from the engine bay. maybe ur not getting any water flowing throu the heater core.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldskoolDA6 »</TD></TR><TR><TD CLASS="quote">maybe you should try changing your thermostat.</TD></TR></TABLE>
Would that make the motor work?
OP: you replaced the motor with one that worked?
If you can't figure it out, just make it work. Add a wire from your battery to the wire that makes it work. Put a switch in the middle.
And that would help the electrical blower how?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr.garagetuner »</TD></TR><TR><TD CLASS="quote">are you sure that ur two way water valve is opening and closing properly where it goes in to the back of the fire wall from the engine bay. maybe ur not getting any water flowing throu the heater core. </TD></TR></TABLE>
Just an FYI, the blower motor runs off of electricity, not water.
There is a fuse in the under-dash panel. It is number 25 in this diagram:
Check if you are getting power or visually check the fuse.
Jonathan_ED3
Audio / Security / Video
Sep 8, 2004 08:42 AM
