Spoon header + Carsound cat install = CEL 65
Old Jun 23, 2002 | 01:56 PM
rockwilda's Avatar
Default Spoon header + Carsound cat install = CEL 65
well, i just finished bolting everything up. checked all o2 sensor's and everything. still throwing a CEL 65. any idea what's wrong?
no exhuast leaks, nothing.
65 - Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater can anyone elaborate?
TIA
Old Jun 23, 2002 | 01:59 PM
Jason's Avatar
Default Re: Spoon header + Carsound cat install = CEL 65 (da_rockwilda)
is it plugged in? easy to forget
Old Jun 23, 2002 | 02:38 PM
rockwilda's Avatar
Default Re: Spoon header + Carsound cat install = CEL 65 (Jason)
sure did Jason. just to double check, the 4 "prongs" just plug into the sensor correct? is it supposed to click or anything?
Old Jun 23, 2002 | 02:43 PM
Jason's Avatar
just tug it to see if it comes apart...if it does, it probably wasn't fully connected
did you drop it at all, could have messed it up while it was out?
Old Jun 23, 2002 | 02:47 PM
rockwilda's Avatar
nope, pulled the grey sensor out of the hole in the frame. pulled the 4 prongs out. and took the cat from under the car. unscrewed o2 sensor put on new cat(securly i might add) and then plugged back in. i double checked(unplugged prongs and plugged back in to make sure it was in all the way) earlier today, and its still throwing after i reset the ECU.
Old Jun 23, 2002 | 03:49 PM
SurferX's Avatar
Default Re: Spoon header + Carsound cat install = CEL 65 (abstraktEK)
My Carsound is throwing CEL 65 too. It's been that way for months, I've never figured out the problem. Did you get the flanges on your Carsound done by a muffler shop? I'm suspecting the welds on mine are leaking due to a crappy muffler shop job. A leaking cat would draw in more oxygen and throw the CEL.
Old Jun 23, 2002 | 04:01 PM
98R-1003 US's Avatar
I had a used Spoon header and used Carsound cat put on my R about 1500 miles ago and have not had any trouble.
Old Jun 23, 2002 | 04:20 PM
FSTASNTZ's Avatar
You pulled the wires from the harness? You did not just disconnect the harness? Am I understanding you correctly?
Jason
Old Jun 23, 2002 | 04:31 PM
rockwilda's Avatar
Default Re: Spoon header + Carsound cat install = CEL 65 (FSTASNTZ)
there's a harness you can disconnect? oh ****.. on me.
ok from what i remember starting from the cat,-> o2 sensor, -> wire -> blue rubber -> hole in frame -> 4 prongs -> grey sensor.
i must not have noticed there was a clip or something..i think i just cost myself some money....
will the CEL cause any damage? limp mode? etc?
Old Jun 23, 2002 | 04:39 PM
B2FiNiTY's Avatar
No limp, just annoying light.
Old Jun 23, 2002 | 07:34 PM
SoCal ITR's Avatar
Default Re: Spoon header + Carsound cat install = CEL 65 (B2FiNiTY)
I hope I don't get that...
Old Jun 23, 2002 | 07:37 PM
sackdz's Avatar
Default Re: Spoon header + Carsound cat install = CEL 65 (SoCal ITR)
On the other end of the spectrum, my secondary O2 is damaged and completely unplugged, and after 30 or so miles I still haven't gotten a CEL
Old Jun 23, 2002 | 09:24 PM
Casey's Avatar
Default Re: Spoon header + Carsound cat install = CEL 65 (sackdz)
can you use the secondary o2 sensor in place of the sensor on the header? my before cat sensor is burnt up and i got a testpipe and was going to wrap the secondary in foil anyway, might as well see if i can make good use of it, thanks
Old Jun 23, 2002 | 09:27 PM
NWPNOMORE's Avatar
Banned
Default Re: Spoon header + Carsound cat install = CEL 65 (CWTypeR463)
the sensors are interchangeable, so you can use the secondary one on the header. As for pulling the 4 pins out of the plug, just get them back in there in the proper locations, and next time keep in mind that it disconnects easily from the harness.
Old Jun 23, 2002 | 09:40 PM
Casey's Avatar
Default Re: Spoon header + Carsound cat install = CEL 65 (NWP4LIFE)
thanks, can i just plug the burnt one in the secondary place and wrap it in foil? im throwing a code 41 right now, will it go away if i interchange the two? thanks
Old Jun 23, 2002 | 11:35 PM
onyx00's Avatar
Probably from the piece of **** Carsound cat.; where did you buy it?
Old Jun 24, 2002 | 12:07 AM
rockwilda's Avatar
Default Re: Spoon header + Carsound cat install = CEL 65 (onyx00)
POS came from IPS so far, im not getting that rattle that everyone seems to get.
Old Jun 24, 2002 | 03:13 AM
Zeus's Avatar
still no codes, no rattle... SMSP Carsound...
Old Jun 24, 2002 | 04:31 AM
stick's Avatar
did the wires come out of 02 sensor harness?
if so, u may have not put the 02 sensor wires back in correclty
they go in like this:
top of clip
Green White
Black Black
make sure its in that order
Old Jun 24, 2002 | 05:01 AM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default Re: Spoon header + Carsound cat install = CEL 65 (stick)
I just had a CODE 65! I took it to the dealer, and it was covered under warranty. I think it's a recall, but anyway the sensor went bad and had nothing to do with the high flow cat. fixed for free.
Old Jun 24, 2002 | 11:09 AM
rockwilda's Avatar
top of clip
Green White
Black Black
oh god...you made my day. THANKS!!!
Old Jun 24, 2002 | 11:20 AM
Mike M's Avatar
Founding Member
To the People blaming a Cat for an O2 Sensor Failure Code
I'll put money that the wires are plugged in incorrectly, or the O2 Sensor was damaged.
Old Jun 24, 2002 | 11:25 AM
rockwilda's Avatar
Default Re: Spoon header + Carsound cat install = CEL 65 (TypeRmsm)
sorry Mike, wasn't trying blame the problem on the Cat. i knew it was a problem
with the o2 sensor. just not exactly what it was until some ppl responded. obviously the code states the problem is with the o2 sensor and not the cat.
Old Jun 24, 2002 | 11:48 AM
stick's Avatar
so did it work? no CEL's?
Old Jun 24, 2002 | 11:53 AM
Dave-ROR's Avatar
You will. I let a 16 year old fix mine.. he drove it for ~30 miles and it came back quiet... heat shields finally fell off
