cuttin cast aluminum intake manifold questions??
Old Nov 7, 2007 | 08:44 AM
b20vtech's Avatar
Default cuttin cast aluminum intake manifold questions??
im going to attemp this myself, b-cuzz my local machine shop are being little bitches... wel, after work yesterday, i stopped at my freindly local Harborfreight and picked up a High speed Air cutter and a 3" Cut off wheel for cutting metal...
Now here's my questions:
Can i use a High speed air cutter and a cut-off wheel to do this?
After cutting this manifold with the tools i got, will it be able to be welded back together??
Looks very easy and i know i can cut this myself, but should i really do it??
Has anyone ever attemp to do this very same thing with a High speed Air cutter?
please inform me if i can be done or cannot/should not be done...
Regards,
Kevin
Old Nov 7, 2007 | 11:33 AM
ROTARY's Avatar
Default Re: cuttin cast aluminum intake manifold questions?? (b20vtech)
sure you can.
yes but don't use cutting oil/grease on the manifold and disk when cutting... also 1. clean 2. pre-heat 3. clean again before welding.
wear leather gloves and eye protection and go for it.
Ive used air/electric die-grinders, chop-saw, band-saw, plasma cutter even a hacksaw to do this but the air die-grinder has been my least favorite due to the droning sound of the compressor.
Old Nov 8, 2007 | 06:09 AM
ManBearPig4silly's Avatar
yeah it will work. Air tools are annoying get some cut off wheels for your grinder.
Old Nov 8, 2007 | 07:22 AM
Jon@ForcedFabllc.com's Avatar
i found cutting aluminum on a air cutt off with a 3" wheel takes for ever and it almost clogs the wheel up, i had better success with a 4.5" electric cutter. but then it was still slow so i break out either my porta band or saw zaw. then fine cut it on the bridge port if i cut it way crooked.
Old Nov 8, 2007 | 09:51 AM
Nick@JEPistons's Avatar
Use a sawzall
Old Nov 8, 2007 | 12:50 PM
b20vtech's Avatar
Default Re: cuttin cast aluminum intake manifold questions?? (ROTARY)
thanks for all the great answers!! HAHAHA it's gonna be done!!
Old Nov 8, 2007 | 03:51 PM
Sobe_Death's Avatar
make sure you get a cutoff wheel specifically made for cutting aluminum. The "all purpose" wheels will just clog up and get you nowhere.
Old Nov 9, 2007 | 10:34 AM
Top Ramen's Avatar
Default Re: (Sobe_Death)
I have used the HF portable band saw to open up cast manis several times and it works fine. Use that - you will be much happier when it it time to put it back together.
Old Nov 9, 2007 | 10:52 AM
k24em2's Avatar
Default Re: (Top Ramen)
I've used a table saw before... Using wood tools for aluminum ftw
In my experience using saws with teeth as opposed to abrasive cut off wheels works better. Carbide toothed saw blades leave a beautiful edge and blazing speed haha
Old Nov 10, 2007 | 03:58 PM
turboteener's Avatar
Banned
Band saw or Sawzall. The little air saw won't be strong enough.
Old Nov 10, 2007 | 05:23 PM
b20turbojason's Avatar
Default Re: (turboteener)
i have used a sawzall before. it worked really well.
Old Nov 10, 2007 | 05:30 PM
tony1's Avatar
Default Re: (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">I've used a table saw before... Using wood tools for aluminum ftw
In my experience using saws with teeth as opposed to abrasive cut off wheels works better. Carbide toothed saw blades leave a beautiful edge and blazing speed haha</TD></TR></TABLE>
Gotta be careful with that one! Table saw works awesome, but can get ugly if you're not careful!
My bandsaw cuts through manifolds like butter.
Old Nov 10, 2007 | 06:38 PM
k24em2's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
My bandsaw cuts through manifolds like butter.</TD></TR></TABLE>
Haha, yea gotta watch the fingers....lol
Old Nov 10, 2007 | 08:38 PM
salival's Avatar
Hey guys,
I work for a radiator shop in New Zealand (Where men are men and sheep are scared).. I work/run the aluminium department there..
We have 2 blades that we use, both teethed, one is 1 or 1.5mm and the other is 3mm..
The 1/1.5mm blade RIPS through tanks/alloy so easily (good for doing intercooler recores or cutting off bosses)
The 3mm is for removing large amounts of materials (i.e cutting off intercooler tank welds)
I suggest goign to see your local boat building store and asking what they use.. we use these ones that boat builders swear by..
Thanks,
Scott R
Old Nov 11, 2007 | 07:21 PM
Wood tools work awesome...with negative rake blades. I wouldnt recomend cutting such in irregular shape though. Could get a little bloody.
boosted hybrid
Aug 13, 2006 04:36 PM
640K Crew
Feb 22, 2006 03:22 PM
Sassafrass
Jan 26, 2006 03:52 AM
D-SPEED
Dec 16, 2001 06:28 PM
Duck Sauce
Sep 27, 2001 08:10 AM
