1988 si
i just bought it but have doubts that its an authentic si. the title says si. but the body says otherwise!!! what are some tell tale signs of it being an authentic si?!
its a shell btw.
its a shell btw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gator88 »</TD></TR><TR><TD CLASS="quote">I thought the 90 had rear discs too. I have an 88 si and the mirrors are NOT body colored. they are black. Cant you also look for a lower sway bar on the si only?</TD></TR></TABLE>
Yep, rear lower sway is Si.
There are a few other tale tale signs but the major ones are covered. D16A6 as an engine stamp on the block would tell you for one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93dagsr »</TD></TR><TR><TD CLASS="quote">awesome! i got an si then! hahaha i closed the door and the moonroof jumped up!!!
Perfectly normal as long as it isnt a huge jump. Mine does it and so do all the other ones ive been in. It is the air pressure the rapid closing door makes. Our sunroofs arent supposed to be sealed, thats why we have drain tubes for the water. Designed to leak, but in an efficient way
</TD></TR></TABLE>Perfectly normal as long as it isnt a huge jump. Mine does it and so do all the other ones ive been in. It is the air pressure the rapid closing door makes. Our sunroofs arent supposed to be sealed, thats why we have drain tubes for the water. Designed to leak, but in an efficient way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">cross reference the vin number at honda.
this topic has been covered a million times and a lot of you are still giving out **** information.
Word.
Don't forget the Si seats, black-only interior, and quicker steering ratio.
Word.
maybe it's these dam c.a. models but my 91 had f/r disc n my 89 has them n the 91 was out of state from the 2nd owner who ran a body shop the 89 was bought 2nd owner in his 30's original owner was 40's neither gave a crap bout cars proved by the $3000 in brake work for a crx... which is more then the car value
sly mantis
Nov 19, 2006 05:39 PM
