p30 piston and crower stage 3
ok i have a B18c1 and i just bought p30 pistons and i want to use crower stage 3 cams, is the cams too big for the pistons or will it be ok to run? if not i also have a set of brian crower stage 2 cams. btw it will also have spoon headgasket and supertech flat valves.
do you have stock retainers?
check this out http://www.c-speedracing.com/h...c.php
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fezzie »</TD></TR><TR><TD CLASS="quote">do you have stock retainers?
check this out http://www.c-speedracing.com/h...c.php</TD></TR></TABLE>
no, everything is supertech i have the whole valve train
im asking if i will be losing hp than gaining, just wanted to see if anyone run this set up? since the cams are big will it have to much overlap for the pistons. when i did the cr calculater it said that i would have 11:9 cr is that true?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fezzie »</TD></TR><TR><TD CLASS="quote">the calculator is accurate but your powerband and idle will suck, i know for sure those p30 will go real good with the stage 2's </TD></TR></TABLE>
so if i get a set of aftermarket pistons like CPs or something with a cr of 12:5+ the stage 3 cams will do better?
now when the cams are not in use, do i keep them oiled? if i do, would regular oil be fine or is their some speical oil? one set of cams i bought used thats why i asking.
are they the crower 63403's? if so, they idle just fine. we dialed mine to the cam card, and it idled all day at 800 rpm. i had them in a 11.5:1 b16, adn they made power to 9300rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch »</TD></TR><TR><TD CLASS="quote">are they the crower 63403's? if so, they idle just fine. we dialed mine to the cam card, and it idled all day at 800 rpm. i had them in a 11.5:1 b16, adn they made power to 9300rpm</TD></TR></TABLE>
yes they are! thats what i thought, i had 404's on my LS before and they did ok, idle was set at 1100, yeah you can say it was kinda high but not to bad, well i'll put them in and see what happens, i just have to change the hondata to run the stage 3, right now the base map is for the stage 2 cams or should i just try running it like that? and whats a cam card?
CA6VTEC
Jul 1, 2005 04:32 PM
