I need some help with the order of washers on banjo from fuel pump...
Old Nov 6, 2007 | 05:09 PM
anothersickhatch's Avatar
Default I need some help with the order of washers on banjo from fuel pump...
im leaking some fuel from the bolt at the end of the fuel rail. i went to the honda dealership and bought two new crush washers, but i dont know the order they go on.
i had another washer on there. its a bit larger and has four tabs on the inside. that washer and the other two crush washers for a total of 3.
what order do they go on? i checked my helms, but i cant find the order. thanks guys.
Old Nov 6, 2007 | 06:05 PM
Default Re: I need some help with the order of washers on banjo from fuel pump... (anothersickhatch)
i meant fuel rail...my bad.
Old Nov 6, 2007 | 08:18 PM
dtapia's Avatar
the 2 crush washers are susposed to go inbetween the fuel damper so 1 washer on the rail and then install the fuel line and washer and damper.
Old Nov 6, 2007 | 09:16 PM
Default Re: I need some help with the order of washers on banjo from fuel pump... (dtapia)
pm'ed
Old Nov 7, 2007 | 04:57 PM
bump.
Old Nov 7, 2007 | 05:02 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtapia &raquo;</TD></TR><TR><TD CLASS="quote">the 2 crush washers are susposed to go inbetween the fuel damper so 1 washer on the rail and then install the fuel line and washer and damper.</TD></TR></TABLE>
X2 The big one with the tabs goes on against the damper.
Old Nov 7, 2007 | 05:12 PM
Default Re: I need some help with the order of washers on banjo from fuel pump... (Chiovnidca)
so fuel rail, crush washer, fuel line, another crush washer (the same), then the washer with the tabs? then the bolt?
Old Nov 7, 2007 | 05:20 PM
bump for being an idiot. where did the larger tabbed washer come from and why wouldnt i have to use it?
johnwohl
Feb 10, 2008 11:07 AM
sohc1200cc
Nov 3, 2006 10:02 AM
LBR92DA-T
Oct 25, 2003 02:21 AM
R6Elmo
Oct 2, 2003 08:09 PM
