What's Wrong (video included)
Old Nov 6, 2007 | 04:20 PM
agiorlando's Avatar
Default What's Wrong (video included)
EDIT: This IS an EF, it's an '89 Civic SI with a '98 EK front-end conversion.
http://youtube.com/watch?v=S8mG1dhv1iU
I've been told "bent connecting rod" - true?
Modified by agiorlando at 6:01 PM 11/6/2007
Old Nov 6, 2007 | 04:42 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
horribly wrong forum there sport. take the oil pan off and find out, easier then us speculating for 100s of posts.
I need 1 whiskey 1 scotch and one
Crx Jimmy's Avatar
Default Re: What's Wrong (agiorlando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agiorlando &raquo;</TD></TR><TR><TD CLASS="quote">What's Wrong ?</TD></TR></TABLE>
Well, first off it appears that you are in the wrong forum, doesnt look like a88-91 civic or crx to me.
It also looks like its missing its timing cover, good job
Old Nov 6, 2007 | 04:48 PM
agiorlando's Avatar
It's an '89 Civic SI, I have a '98 front-end conversion, sorry. haha
I took the timing belt cover off just before starting it, so I can see if it behaved weirdly.
Old Nov 6, 2007 | 04:49 PM
Tippyman's Avatar
Lol, wow.
Old Nov 6, 2007 | 04:58 PM
ComeOnKip's Avatar
god kill me so i don't have to endure anymore of these threads.
Old Nov 6, 2007 | 05:45 PM
grog's Avatar
did you start the car after it was already running? it sounds like you ground some teeth off the flywheel.
i guess you could take out the starter or the lower flywheel cover and try to inspect it.
Old Nov 7, 2007 | 12:58 AM
STREETWERKZ's Avatar
when you suspect something is wrong, stop trying to start it. sometimes you can catch the problem before it gets too bad.
Old Nov 7, 2007 | 05:44 AM
90efhatch's Avatar
Default Re: What's Wrong (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">when you suspect something is wrong, stop trying to start it. sometimes you can catch the problem before it gets too bad.</TD></TR></TABLE>
agreed. take the oil pan off and see what that knocking is.
Old Nov 7, 2007 | 11:03 AM
agiorlando's Avatar
Default Re: What's Wrong (90efhatch)
Is it an easy task to take the starter off? or the lower flywheel cover?
I'd hate to have to resort to taking the oil pan off just yet.
Old Nov 7, 2007 | 11:39 AM
welfarepc's Avatar
what are you talking about? just yet? its SO EASY and all you need is a $10 gasket, a 14mm wrench, 12 mm wrench, 10mm deep socket, and extension. you dont even need to take your starter off...
much better than removing the head gasket, buying new head bolts and a new head gasket.
have you done a compression test? leak down test? checked your spark plugs? getting enough fuel? do you even have gas in your car? what is your timing set to? god damn it
........or if you dont know much about cars tow it to a shop
Old Nov 7, 2007 | 11:55 AM
agiorlando's Avatar
Would removing the oil pan allow me to tell if it's the flywheel? if it's a bent connecting rod?
What exactly can removing the oil pan tell me?
Old Nov 7, 2007 | 11:56 AM
welfarepc's Avatar
man, take it to a shop
thats the best advice you will get
Old Nov 7, 2007 | 12:01 PM
agiorlando's Avatar
Default Re: (welfarepc)
The point of a place like this is to get help from other members, to eliminate the need for a shop.
If you don't want to help, you could just stay out of the thread? maybe?
Old Nov 7, 2007 | 12:07 PM
90efhatch's Avatar
in the video when the car tried starting I could hear it try and fire then there was a grinding sound did you try and start it again real fast or did you just keep the key turned?
Old Nov 7, 2007 | 12:11 PM
agiorlando's Avatar
It was started once, the loud screech at the end was something the car made on it's own, it wasn't being attempted to start again. :/
Old Nov 7, 2007 | 12:19 PM
90efhatch's Avatar
Pull the starter out put it in gear push the car forward while looking at the flywheel and see if there are teeth missing off of it. you will need somebody to help push of course. did it just start doing this or has it been starting weird for a while?
Old Nov 7, 2007 | 12:23 PM
agiorlando's Avatar
One day I was coasting in neutral and the engine just jerked and stopped. I don't exactly remember if I was in neutral or if I was in 1st gear with the clutch in.
Old Nov 7, 2007 | 12:25 PM
90efhatch's Avatar
does not really sound like a flywheel problem to me. have you checked the timing belt it might have jumped time.
Old Nov 7, 2007 | 12:32 PM
agiorlando's Avatar
That's what a friend of mine suggested, I took the timing belt cover off and everything looked fine... Even for the few seconds it was running it rotated fine.
Are there any other simple things that could be wrong? Like the guy before mentioned spark plugs and what not?
Old Nov 7, 2007 | 12:40 PM
grog's Avatar
Default Re: (90efhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90efhatch &raquo;</TD></TR><TR><TD CLASS="quote">does not really sound like a flywheel problem to me.</TD></TR></TABLE>
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agiorlando &raquo;</TD></TR><TR><TD CLASS="quote">One day I was coasting in neutral and the engine just jerked and stopped. I don't exactly remember if I was in neutral or if I was in 1st gear with the clutch in.</TD></TR></TABLE>
owch, sounds like its gonna have to go under the knife. I doubt you will figure anything out until you open it up.
Old Nov 7, 2007 | 12:46 PM
grog's Avatar
Default Re: (grog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc &raquo;</TD></TR><TR><TD CLASS="quote">man, take it to a shop
thats the best advice you will get </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agiorlando &raquo;</TD></TR><TR><TD CLASS="quote">The point of a place like this is to get help from other members, to eliminate the need for a shop.
If you don't want to help, you could just stay out of the thread? maybe? </TD></TR></TABLE>
hey, in all honesty, he is trying to help you.
you might be in over your head, sorry i cant sugar coat that. But really, the best thing for you to do is probly to take it to a shop or mechanic friend.
good luck
Old Nov 7, 2007 | 01:18 PM
grog's Avatar
Default Re: (20ls01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20ls01 &raquo;</TD></TR><TR><TD CLASS="quote">i would be more concerned with how it looks than how it runs</TD></TR></TABLE>
Ya, maybe the motor is rejecting the front end. just kidding,to each his own.
Old Nov 7, 2007 | 01:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agiorlando &raquo;</TD></TR><TR><TD CLASS="quote">Is it an easy task to take the starter off? or the lower flywheel cover?
I'd hate to have to resort to taking the oil pan off just yet.</TD></TR></TABLE>
so fire the friggan motor up a thousand times and turn a minor problem into a major issue.
...and that is GREAT ADVICE. dont knock it until you try it.
jayelowell
Honda Civic (2006 - 2015)
Mar 8, 2008 04:16 AM
NHswaps13203
Oct 22, 2007 04:25 AM
DannyB626
Oct 29, 2006 11:35 PM
Gutted Si
Jun 22, 2006 09:01 PM
whitest
May 22, 2006 01:06 AM
