Distributor and fuel rail conversion
Old Nov 6, 2007 | 09:57 AM
Acidcrakker's Avatar
Default Distributor and fuel rail conversion
Okay got transmission off
Now Do i need to convert the dizzy and the fuel rail to h22a from the h23a1?
Old Nov 6, 2007 | 10:10 AM
M2B4's Avatar
Default Re: Distributor and fuel rail conversion (Acidcrakker)
h23 and h22 use same distributor and fuel rail.
Old Nov 6, 2007 | 10:26 AM
Default Re: Distributor and fuel rail conversion (M2B4)
JDM fuel rail is reversed. So keep the dizzy and swap fuel rail.
Old Nov 6, 2007 | 10:55 AM
underbelly's Avatar
Drop the dizzy, and the rail.
Old Nov 6, 2007 | 11:44 AM
Default Re: (underbelly)
Im sorry drop the what????? Please explain A little more.
Old Nov 6, 2007 | 12:41 PM
M2B4's Avatar
Default Re: (Acidcrakker)
the parts are the same jdm is reversed you can either swap rails or fab a longer fuel line. theres no need to "drop" either part....
Old Nov 6, 2007 | 12:44 PM
mgags7's Avatar
use your h23 distributor, that way you won't have to mess with the coil wiring.
Old Nov 6, 2007 | 12:56 PM
Default Re: (mgags7)
wow this is a lot of work. Im just about fed up for today.
I gotta get the crank pulley off the h23 to do the tensinor conversion.
I have to wire up the whole motor
I have the crank pulley tool, but its just not working right now. We bent the damn thing. Anyone ever cut the bolt off.
After its all wired up and its converted then its ready to be dropped back in.
Old Nov 6, 2007 | 01:31 PM
mattsnooz's Avatar
dont cut the bolt off..you'd be in a world of
NowABeliever's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">wow this is a lot of work. Im just about fed up for today.
After its all wired up and its converted then its ready to be dropped back in.</TD></TR></TABLE>
Ive cut the bolt off before but i would not suggest it considering that one bolt will run you 30$ at honda and good luck finding it in a junkyard, even if you find one they wont sell just that bolt. Trust me i tried!
Old Nov 6, 2007 | 01:51 PM
Default Re: (NowABeliever)
Frankly I just want the motor to run. But I have to be patient with this. Very time consuming here. I have to get the damn timing covor off cause I sold it already. I think Im parting out my H23a1 block as well.
Old Nov 6, 2007 | 03:04 PM
Cottonwoodz's Avatar
Default Re: (M2B4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">the parts are the same jdm is reversed you can either swap rails or fab a longer fuel line. theres no need to "drop" either part....</TD></TR></TABLE>
Just use the h23 dizzy, coil and fuel rail.. Why "fab" anything when you already have the right parts, on your old motor.....
Old Nov 6, 2007 | 04:38 PM
THC07's Avatar
Default Re: (Cottonwoodz)
you can alos use the F series fuel rail if you want the fuel inlet to be on the passenger side.
Old Nov 6, 2007 | 07:38 PM
how about NO.... He has a H23, so there for he would use the H23 rail, dizzy and coil.....
This is no debate.....
Old Nov 6, 2007 | 07:51 PM
Well I got the fuel rail converted already and the dizzy will only take me like 20 mins to do.
Will all the wires from the wireharness on the h23a1 match the h22a? Im asking this because its in my todo list for tommmorrow. Are all the wires the same except for the Vtec wires?
Old Nov 6, 2007 | 09:01 PM
Rosko's Avatar
yeah all you have to do is wire up vtec. if your car is newer then 92 and you have a vtec engine harness you probably wont even have to do that.
Old Nov 7, 2007 | 04:07 PM
Default Re: (Rosko)
Okay the car is a 92 and the Vtec harness is chopped.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">yeah all you have to do is wire up vtec. if your car is newer then 92 and you have a vtec engine harness you probably wont even have to do that.</TD></TR></TABLE>
Back to swapping dizzies. Okay the h23a1 dizzy and h22a dizzy are both diffrent. The h23a1 has 5 wires plus that extra piece that plugs from the fifth wire hole into the extra piece of distrubutor. The h22a only has 4 wires, which all go to the spark plugs. I swapped dizzies and also bolted that extra piece onto the head. That will work or do I even need the extra piece of equipment from the h23a1.
Old Nov 7, 2007 | 04:13 PM
mgags7's Avatar
use all of the h23 stuff
Old Nov 7, 2007 | 09:21 PM
M2B4's Avatar
dude you are making this difficult.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">use all of the h23 stuff</TD></TR></TABLE>
socialistic
Feb 26, 2008 02:30 PM
BokChoy
Dec 21, 2005 08:43 PM
bb4socal
Nov 20, 2005 01:38 PM
done
May 13, 2004 09:29 PM
