Transmission removal
Old Nov 6, 2007 | 07:59 AM
Acidcrakker's Avatar
Default Transmission removal, now changed to installing
Okay so Im pulling bolts off on the trannie. It looks like to get it off there are two sections of the tranismission that need to be removed in order for it to fully work. Correct. Im looking at the helms for transmission removal and it is showing me how to take it 100 percent apart. Mabey im looking at the wrong section, but any help greatly appreciated.
Modified by Acidcrakker at 3:44 PM 11/6/2007
Old Nov 6, 2007 | 08:23 AM
mgags7's Avatar
you need to take all of the bolts out of the rear mount and take it off, the bolts that go into the trans from the backside of the block, then all of the bolts around the bellhousing, don't forget the starter.
Then there is the little 90* brace on the bottom in front. After that it should pop right off.
Old Nov 6, 2007 | 08:45 AM
Default Re: (mgags7)
what about the bolts to the shifter thing?
Old Nov 6, 2007 | 08:58 AM
Hawkze_2.3's Avatar
Default Re: (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">what about the bolts to the shifter thing? </TD></TR></TABLE>
No, just unhook the shifter cables. Or do you mean the bracket that holds the cables?...yeah, I think you'll have to unbolt that (can't remember exactly), but it's pretty much just common sense.
Old Nov 6, 2007 | 09:06 AM
mgags7's Avatar
I like to just leave the cables in that bracket, and unbolt it.
Old Nov 6, 2007 | 09:56 AM
well I got it off. Thanks now Im working on converting a few things. See you in my new thread
Old Nov 6, 2007 | 11:27 AM
Now putting it back on. I got it pretty much lined up, the only thing is that the thing that spins the fly wheel, isnt matched up in the grooves. How can I turn the flywheel, to get the spinner in the hole?
The language of a Noob...
Old Nov 6, 2007 | 11:45 AM
Bump....
Old Nov 6, 2007 | 12:43 PM
mgags7's Avatar
You mean the splined shaft coming out of the transmission wont line up with the flywheel?
Did you change the clutch? Use the alignment tool when you did it?
You normally have to just jiggle it to fit, but if the clutch disk isn't lined up with the flywheel right, it won't go in at all...
Old Nov 6, 2007 | 02:04 PM
Dangers of putting clutch on withut using clutch alignment tool? I did today.
Old Nov 6, 2007 | 03:43 PM
Default Re: (Lude17)
okay itson there, just not torqued on. leaving it for mannana
Old Nov 6, 2007 | 03:55 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude17 &raquo;</TD></TR><TR><TD CLASS="quote">There's no danger in putting the transmission on without aligning the clutch. The transmission spline will align everything if you get it in there and get everything torqued down. The alignment tool just makes everything go together much easier.</TD></TR></TABLE>
DELETE YOUR POST.
Once you tighten the pressure plate down you will NOT be able to move the clutch disk around by hand
Old Nov 6, 2007 | 04:22 PM
xxmastermindxx's Avatar
wow how will the input shaft move the clutch disc when it's torqued down??
the farthest away from procedure that i went, was using a broomstick that somehow fit the flywheel perfectly, and enough electrical tape around it to perfectly match the clutch disc. slight amount of jiggling and the tranny slid right in.
i was doing this at a friends house 90 miles from chicago in the middle of cornfields though, and didn't have the tool lol
Old Nov 6, 2007 | 04:26 PM
Default Re: (xxmastermindxx)
Well how bout this. I used a screw driver to jiggle the flywheel while we bolted the trannie into the motor.
Old Nov 7, 2007 | 12:41 PM
Lude17's Avatar
Sorry I read my post and I'll delete it. However, what I meant was that you can align it like he said with a screwdriver or whatever and get it close enough. It may take a couple tries but if you get the spline in there with everything torqued down, (the pressure plate) its okay, by "torqued down" in my first post I meant the tranny bolts. Sorry guys
Old Nov 8, 2007 | 09:20 AM
Default Re: Transmission removal, now changed to installing (Acidcrakker)
If the tranny is on there torqued and the flywheel still turns with the crank, is the tranny on there right?
Renegade
Nov 28, 2012 11:55 AM
trav143
13
Oct 5, 2008 08:08 PM
E.Honda
Oct 29, 2007 06:22 AM
crxluv2
Dec 19, 2005 03:01 PM
